Old 06-08-2021, 08:52 AM   #1
Steve in Denver
Steve in Denver's Avatar
Default 1934 Pickup dash
I am trying to help a friend find parts for his '34 pickup. To start with, he needs all the instruments for the dash. We have a swap meet coming up this weekend (June 12-13, 2021) in Denver and I would just like to know what to look for. Here is a picture of what he has, basically, nothing. I would appreciate a photo of a correct dash and closeup of the instruments.
I'll post some other photos of his truck, because I know everyone likes to see them.
Steve
Steve in Denver is offline   Reply With Quote
Old 06-08-2021, 10:07 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1934 Pickup dash
Here is a speedometer,ammeter and gas gauge.That speedo and ammeter are on EBAY right now .The gas gauge will have an F instead of P.
Here is a link to one sold a few yrs ago that was advertised on the HAMB
https://www.jalopyjournal.com/forum/...auges.1048454/
Old 06-08-2021, 11:14 AM   #3
DavidG
DavidG's Avatar
The dash/instrument panel shown in the third photo is the correct one for either a '33 or '34 closed cab, be it pickup or big truck.
Old 06-08-2021, 03:24 PM   #4
Steve in Denver
Thanks, what kind of supply line does that fuel gauge take? I know it is not electrical.
Old 06-08-2021, 03:33 PM   #5
JSeery
JSeery's Avatar
It is a complicated setup of tubing and an indicator fluid. You have to have the tank unit that goes with it and it just about has to be rebuilt by one of the gauge shops unless you really know what you are doing. This is a diagram of a 35, not the same, but I think they are similar.
Old 06-08-2021, 03:47 PM   #6
Steve in Denver
Thanks, I appreciate that. My friend will need a new gas tank anyway, some previous owner took it out and it got lost many years ago, so he will need the tank and sending unit.
Old 06-08-2021, 09:45 PM   #7
al's28/33
al's28/33's Avatar
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 06-08-2021, 09:48 PM   #8
al's28/33
al's28/33's Avatar
Steve you will find rebuildable speedos on epay along with decent amp meters but I used a later model Ford fuel gauge that a local mechanic was able to calibrate with a Bob Drake fuel sending unit in the tank. It has worked well for the past 15 years and counting..... the choke and throttle hand knobs are also repops from Macs.
Take a look at my '33 V8 album,......Good luck the trucks are fun!!!!!!!
Old 06-08-2021, 10:24 PM   #9
Steve in Denver
Many thanks, I appreciate all the info. I understand the different fuel gauge and will leave it up to my friend as to how he wants to proceed.
Old 06-08-2021, 10:44 PM   #10
VeryTangled
VeryTangled's Avatar
Nice pics in this thread! Way to go guys.
-Jeff H
Old 06-08-2021, 11:37 PM   #11
deuce lover
Originally Posted by al's28/33 View Post
Well done on that gas gauge modification !!.
Old 06-08-2021, 11:42 PM   #12
deuce lover
The 33-34 unit is clocked differently although will work on a pickup( I think). The vent tube on the 33-34 is perpendicular to the frame(chassis) when installed. The 35 unit won't clear the floor of the body in that location.
Old 06-09-2021, 06:46 AM   #13
Steve in Denver
Thanks, sounds like it will be best just to order the sending unit and the tank at the same time, probably from Mac.
Old 06-09-2021, 06:48 AM   #14
sugarmaker
sugarmaker's Avatar
Steve,
Your friend has a good project there. I also am starting into something like this and do appreciate the pictures and the knowledge from these folks on the Ford Barn. And their willingness to share information! All good stuff!
Your friends truck has not had a easy life in the trees. Glad he is going to save it!
So just because I can, I am going to post this dash picture that should arrive in my shop this afternoon. It resides in a 32 truck. David and others can tell us about the differences between this and what your looking for. It might help your friend and others? Interesting about the complex fuel gauge system!
Good luck at the swap meet! I have not been to one of those in 40 years. Humm may have to go to some???
Regards,
Chris
Old 06-09-2021, 07:13 AM   #15
Steve in Denver
Yes, this one has definitely been in the trees for a few years. Here it is last winter. With leaves on the trees, it cannot even be seen from the street in the summer.
Old 06-09-2021, 07:17 AM   #16
Steve in Denver
And as an encouragement to Larry, I had Charlie bring his dad's still running, '34 over so Larry would have something to look forward to.
Old 12-01-2021, 01:40 AM   #17
JD
Charlie's Dad's truck looks great!
JD is offline   Reply With Quote
