05-11-2021, 02:49 PM | #21 |
Re: dropping the pan
Picked up a deep well 1/2" socket - 1/4" drive, wobble/universal, and a 6" extension from Home Depot the other day and was able to get on top of every bolt on the pan after removing the inspection plate. It fit fine.
05-12-2021, 04:18 PM | #22 |
I use a 1/4" cordless impact driver with a 1/2" nut driver with 6" shank.
I use it for off and on... Good Day! |
05-12-2021, 04:18 PM | #23 |
Double post...Second one removed ...Tried to .....
06-22-2021, 11:57 AM | #24 |
What kind of gasket do most use when they reinstall the pan? Also, is there something to do to some "rear seal" when you are doing this job?
06-22-2021, 12:38 PM | #25 |
I also had to grind the socket to get a good fit, it is now my oil pan only socket.
