Old 03-20-2014, 05:34 PM   #1
Peterooster
Peterooster's Avatar
Default 32 cowl mounting front bracket
If someone could help identify the front cowl mounting bracket would bring joy. The question, is bracket worn to a taper or do I need to repair by adding weld and how does this mount to the frame over the firewall. Thanks, Pete
Peterooster is offline   Reply With Quote
Old 03-20-2014, 06:35 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 cowl mounting front bracket
As shown in the photo below, the subject bracket does not touch the frame. It serves to tighten the cowl down and around the firewall via the two 7/16-20 x 2 1/4" hex bolts through the frame (one each side of the cowl).
Old 03-20-2014, 07:05 PM   #3
Peterooster
Thank you! Pete
Old 03-20-2014, 07:32 PM   #4
PeteVS
PeteVS's Avatar
Is there welting between the firewall and the frame?
Old 03-21-2014, 12:41 AM   #5
Conair007
Conair007's Avatar
That's welting is for the hood sides.
Never give up, Always fight till hell freeze's over, then we fight on ICE !
Conair007 is offline   Reply With Quote
Old 03-21-2014, 04:59 AM   #6
DavidG
DavidG's Avatar
Yes, there was flat welting between the firewall 'feet' and the chassis frame. There were two pieces of it about 1" x 2" per side. It was the same material and thickness as used between the body and the frame and the front fenders and the frame.
Old 03-21-2014, 06:37 PM   #7
PeteVS
PeteVS's Avatar
Thanks!
