Old 09-23-2020, 10:17 AM   #1
1931flathead
Default Stromberg carbs
Have a intake that set up to run 4 carbs
Do you run all 4 or just 2 and use linkage to run the other ones
1931flathead is offline   Reply With Quote
Old 09-23-2020, 11:30 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Stromberg carbs
Given the design of most 4-carb intakes, they are designed to run all four in unison. Unless you have a larger cubic inch engine and are into real racing, you might be best off with four of the smaller 81 Strombergs.
Old 09-23-2020, 11:35 AM   #3
tubman
tubman's Avatar
And that can get real expensive.
Old 09-23-2020, 11:56 AM   #4
1931flathead
It's a inline 6 301 cubic inch with a 588 camshaft for a hot rod
Old 09-23-2020, 12:40 PM   #5
frnkeore
frnkeore's Avatar
In your case, you should be able to run 2, with the other 2 on a progressive linkage.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 09-23-2020, 02:10 PM   #6
tubman
tubman's Avatar
Now you have piqued my interest. Would you mind sharing what kind of an engine this is? The only 300+ ci vintage inline sixes I can think of are Hudsons (308 ci) and GMC's (302 ci). Since yours is smaller, I'm stumped.
Old 09-23-2020, 02:57 PM   #7
1931flathead
Chevy 292 +.060 custom pistions lump ports close to 10to1 compression custom intake 588 intake 581 exhaust 234 intake 234 exhaust at .050 lob Sep 112
Old 09-23-2020, 03:15 PM   #8
tubman
tubman's Avatar
OK. That explains it. (Modern stuff.) Sounds healthy, though. It might run OK progressive, but I bet straight would be better. The only time I ran 4 97's was on the 331 Hemi in my racecar (straight linkage, of course). It ran great and was quite fast, but for some reason, I had to go through the carbs every year. I finally had enough of that and went to two large-base 2G's on a different manifold; it ran about as good and the carburetors are completely trouble free. (One of the guys I raced with ran a 320 ci Buick straight eight with 5 97's (straight linkage as well.)
When I had the first setup, I ran across an article someplace (maybe on the H.A.M.B.) that explained how to properly set up 4 in a row with a straight linkage for the street. Maybe I can find again it if you're interested.
Old 09-23-2020, 03:41 PM   #9
1931flathead
The gm carbs are good for shure but they don't look as good as the older ones
Old 09-23-2020, 06:37 PM   #10
Zeke3
Zeke3's Avatar
How about three Carter YH side draft carburetors, like the early Corvettes?
Also used on turbocharged Corvairs and some Nash, I think.
Zeke3 is offline   Reply With Quote
