03-14-2023, 09:54 AM | #1 |
1CM Camshaft
I posted earlier requesting a picture of a 1CM "crankshaft" when I meant to say "camshaft".
Let me try this again, does anyone have picture of a 1CM camshaft? Thank you. |
03-27-2023, 06:00 PM | #2 |
Re: 1CM Camshaft
Btt
03-27-2023, 06:34 PM | #3 |
Re: 1CM Camshaft
Visually you will not see any difference from an EAB to a 1CM cam.
03-27-2023, 07:24 PM | #4 |
Re: 1CM Camshaft
03-27-2023, 08:25 PM | #5 |
Re: 1CM Camshaft
So far I have never seen a cam marked 1CM.
03-27-2023, 11:05 PM | #6 |
Re: 1CM Camshaft
03-28-2023, 08:41 AM | #7 |
Re: 1CM Camshaft
03-28-2023, 09:26 AM | #8 |
Re: 1CM Camshaft
IIRC the one in my jalopy had EAB cast right on the blank. Only one I've had though
03-28-2023, 09:38 AM | #9 |
Re: 1CM Camshaft
Attached are pictures of two 8CM Merc cams I recently sold. Specs for the '49-'51 cams are .338"/.333" int./exh.
03-28-2023, 09:58 AM | #10 |
Re: 1CM Camshaft
I have 8CM, 8BA, EAB and EA cams.
03-28-2023, 10:23 AM | #11 |
Re: 1CM Camshaft
I have pictures of the 8BA and EAA that came out of the old block and the new block. When I assembled the new block, after the machine work was finished, I used 1CM cam, but lost the pictures of it when my computer crashed.
03-28-2023, 10:43 AM | #12 |
Re: 1CM Camshaft
03-28-2023, 10:46 AM | #13 |
Re: 1CM Camshaft
Thanks for looking. Still hoping someone out there, has one.
03-30-2023, 05:48 AM | #14 |
Re: 1CM Camshaft
Here are 4 NOS 8RT cams off the the grinder yesterday. Returning as “Smiley” cams.
03-30-2023, 06:58 AM | #15 |
Re: 1CM Camshaft
What’s a smiley cam?
What is the prerequisite for regrinding a 59 AB cam. I would like the specs of a late Mercury cam, or a bit better. Going in early block with a merc crank, basically stock. I have a few prewar and 40s cams. How does a reground cam affect the drive train? Do you need to have longer valves or are the adjustable lifters enough to adjust the valves? And lastly, what does it cost? Thanks |
03-30-2023, 07:49 AM | #16 |
Re: 1CM Camshaft
03-30-2023, 01:24 PM | #17 |
Re: 1CM Camshaft
I take it Smileys are the L-100 cam
03-30-2023, 03:56 PM | #18 |
Re: 1CM Camshaft
03-30-2023, 04:33 PM | #19 |
Re: 1CM Camshaft
If you take a stock 8RT cam, and regrind it, wouldn’t you have lower lift than the stock 8RT? Or are the lobes built up prior to the regrind?
JB |
03-30-2023, 04:45 PM | #20 |
Re: 1CM Camshaft
No you have way more lift. Stock just over.300”L100 right at.370. Base circle is slightly smaller.
Lobes are not build up. This is a standard regrinding procedure Last edited by KiWinUS; 03-31-2023 at 06:09 AM. |
