01-11-2018, 10:19 PM | #1 |
2 Blade Fan
Im changing from a 4 blade to a 2 blade after doing valve job. I bought the fan from Snyders. Has anybody bought one from them? Mine came with what looks like a crack and casting flaw that is powder coated over. Is this normal for a recasting assy.
01-11-2018, 10:29 PM | #2 |
Re: 2 Blade Fan
Don't Know about crack in casting but be sure and scrape the Powder Coating out of the taper area that mounts on shaft. I bought 30 model that had a knock that turned out to be the powder coating had flowed out and left fan loose on water pump shaft ate the keyway and shaft up. Previous owner thought it was Timing gear and replaced them, knock was still there so he sold it as is! I replaced Fan and pump quiet as a mouse now.
01-11-2018, 10:34 PM | #3 |
Re: 2 Blade Fan
Talk to Snyder's, if it is defective I'm sure they will make it right.
01-11-2018, 11:43 PM | #4 |
Re: 2 Blade Fan
I've had Snyders fans on several cars I have owned. At one time the advice around town was make sure of the taper before you buy. That problem has been resolved and I have never had a replacement that didn't bolt on and use with no adverse effects. The powder coating issue is easily handled with a pocket knife. In your example, if it were mine I'd get on the phone and find out what they will recommend. They do take care of business in a professional manner.
01-11-2018, 11:56 PM | #5 |
Re: 2 Blade Fan
I bought another from Snyder and just like Daveymc29 says Pocket Knife will cut that powder coating right out of there! I cut it out with the pocket knife I have been carrying since 1962. The previous owner did not do that though. always good luck with Snyders Parts.
01-11-2018, 11:56 PM | #6 | |
Re: 2 Blade Fan
Good enough.. Isn't. |
01-12-2018, 12:04 AM | #7 |
Re: 2 Blade Fan
Cracks in the aluminium casting? Photos will give us something to go on.
01-12-2018, 03:07 AM | #8 |
Re: 2 Blade Fan
I bought a 2 blade recently from Snyders and it was fine. Not sure about your crack.
As synchro says, pictures please. |
01-12-2018, 07:36 AM | #9 |
Re: 2 Blade Fan
I would not take a chance if you think there is a crack in blade.
I have had a fan blade fail while driving. Not pretty. Enjoy. |
01-12-2018, 10:20 AM | #10 |
Re: 2 Blade Fan
Just too many stories about cracked two blade fans breaking and damaging the cars and people. I bought one several years ago from Snyders and some months later noticed a noise thought to be timing gears. Took the cover off and the gears were fine. I noticed a crack in the fan which was about to let loose. Replaced it with a four blade plastic fan and will never go back to the two blade type. Points cars would be another point, however.
Glen
'31 Model A Deluxe Roadster '31 Chrysler Model 70 Sedan '88 Pontiac Fiero GT '36 Auburn Boattail Speedster replica |
01-12-2018, 10:48 AM | #11 |
Re: 2 Blade Fan
01-12-2018, 10:56 AM | #12 |
Re: 2 Blade Fan
I have used many Aluminum two blade fansfrom Snyders and had no problem, but in this case I would call Snyders. I am sure they will replace it.
01-12-2018, 11:34 AM | #13 |
Re: 2 Blade Fan
I think that is a parting line flash that didn't get ground off smooth before the powder coating.
I would call Snyder's and return it to be Safe tho.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
01-12-2018, 01:21 PM | #14 |
Re: 2 Blade Fan
That looks like a crack in the hot die that the fan was cast in to me. I have had lots of experience with the die cast industry since 1969 and to me it looks like a crack in the die it's self and is transferred on to the part or casting from which it came out of. I still would do some investigation.
01-12-2018, 01:32 PM | #15 |
Re: 2 Blade Fan
Send that picture to snyder’s. They will work with you. I wouldn’t install that on my A. It’s not worth all of the problems you will have if the blade lets go.
31 Tudor 66 Bonneville 57 Chevy pickup 27 T roadster pick up |
01-12-2018, 02:59 PM | #16 |
Re: 2 Blade Fan
Grind that down and you will only find the casting mark.
Oklahoma City Model A Restorers Group. |
01-13-2018, 04:10 PM | #17 |
Re: 2 Blade Fan
If you modify the fan, Snyder's may not take it back. Call them, they'll probably send you a replacement.
AL in NY |
01-13-2018, 08:18 PM | #18 |
Re: 2 Blade Fan
And send this one to me.
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 01-14-2018 at 02:40 AM. |
01-13-2018, 10:18 PM | #19 |
Re: 2 Blade Fan
Snyder and Mikes are great vendors. If you don't modify it they will replace it for you. Just give them a call. Do not use this one to be on the safe side.
Henry' s 31 |
