11-04-2017, 08:30 AM | #1 |
39 trans lube
Hello this past summer I have been running 140 lube in my trans,what type of trans lube should I use for Midwest winter,if I decide to take it out on a clean dry road day,thats below freezing?
11-04-2017, 09:29 AM | #2 |
Re: 39 trans lube
if your only going to use it a few times during the winter and car is parked indoors I would stick with the 140w , but 85/90w sta-lube with GL4 sold at napa would be best
11-04-2017, 09:35 AM | #3 |
Re: 39 trans lube
I always run a multi viscosity oil like 75-140. Pick your favorite brand.
11-04-2017, 09:37 AM | #4 |
Re: 39 trans lube
One minor correction, there is no such thing as 140w. "W" stands for Winter and the highest "W" rating on gear lube is 85w (some marine gear lubes are rated at 90w). The "w" rating vs the non-w rating relates to the temperature at which the lube is rated. Non-w SAE lube is rated at 212 deg F, w rated lube is rated at 0 deg F.
11-04-2017, 09:47 AM | #5 |
Re: 39 trans lube
CORRECTION> No need to call if you read this article. http://www.substech.com/dokuwiki/doku.php?id=gear_oils Last edited by 19Fordy; 11-04-2017 at 09:58 AM. |
