Old 10-30-2011, 01:04 PM   #1
sonny
sonny's Avatar
Default 32 fuel gauge tubing
Does anyone have the ticket on how to cut the very small copper air line to the gauge without crimping it?
sonny is offline   Reply With Quote
Old 10-30-2011, 02:52 PM   #2
Jake
Jake's Avatar
Default Re: 32 fuel gauge tubing
Sonny: I used a fine tooth jewelers saw.
Jake is offline   Reply With Quote
Old 10-30-2011, 04:30 PM   #3
jim1932
jim1932's Avatar
Seems you could put a nail in the end to support it then cut the tube and the nail with a dremel?
jim1932 is offline   Reply With Quote
Old 10-30-2011, 05:48 PM   #4
sonny
sonny's Avatar
How do you get the nail in the end?
Old 10-30-2011, 06:57 PM   #5
Lawson Cox
Lawson Cox's Avatar
how do you get the nail in the end?
my thoughts exactly. Lol
Old 10-30-2011, 07:46 PM   #6
jim1932
jim1932's Avatar
I was thinking you cut it a little longer than you need then insert the nail in the distorted end and recut.
Old 10-31-2011, 12:02 AM   #7
35fordtn
35fordtn's Avatar
My local hardware store had a extra small tubing cutter that did it perfectly
35fordtn is offline   Reply With Quote
Old 10-31-2011, 03:19 PM   #8
B-O-B
B-O-B's Avatar
Use a B F H heh heh he
use a fine tooth hacksaw don't force it then ream/clean the inside edge with a small round file & blow air thru to remove any filings
B-O-B is offline   Reply With Quote
Old 10-31-2011, 04:09 PM   #9
sonny
sonny's Avatar
I think I solved My own problem. Even using the fine tooth hacksaw, the soft very small copper tubing would close up. Using a slightly worn carbide ceramic tile blade, it worked. The kind of blade you put in a hacksaw frame. Just be gentle and go slow. My wife liked that last sentence. Thanks for all the responce.
Old 10-31-2011, 04:53 PM   #10
32wetzel
Go to your local hobby shop to find a tubing cutter to use on the small 1/8" tubing. That's where I bought mine. Home Depot and Lowes won't have one for tubing that small.
32wetzel is offline   Reply With Quote
Old 10-31-2011, 04:58 PM   #11
tdlmomowers
tdlmomowers's Avatar
I have a mini tubing cutter that I bought at NAPA, years ago. It works great on 1/8in. copper line. Just don't force it too hard, be gentle and go slow. Now my wife liked my last comment. LOL.
tdlmomowers is offline   Reply With Quote
Old 11-03-2011, 12:31 PM   #12
jerseyboy
jerseyboy's Avatar
Welcome back R. Wetzel!
Keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
