Old 09-15-2021, 08:00 PM   #1
Utopia Texas
Utopia Texas's Avatar
Default Pertronix With Original Pop Out Switch….
My ‘31 has the Pertronix module in the distributor but a repro key switch. Any problems if I still use the Pertronix unit but install a pop out switch? Thanks…
Utopia Texas is offline   Reply With Quote
Old 09-16-2021, 11:01 AM   #2
Jim Brierley
Default Re: Pertronix With Original Pop Out Switch….
FSI says don't use a pop-out. Original Ford wiring had the coil hot at all times and the switch provided the ground for the points. Your switch undoubtedly connects the battery to the hot side of the coil and the ground side is done automatically. Grounding of electronic devices is extremely important, I ground my FSI directly to the battery.
Jim Brierley is offline   Reply With Quote
Old 09-16-2021, 05:09 PM   #3
Patrick L.
Patrick L.'s Avatar
How is the current switch wired ?
Old 09-16-2021, 05:46 PM   #4
jayvee34
jayvee34's Avatar
If you wire from the battery side of the terminal box to the power side of the
ignition switch, wire from the other side of the ignition switch to the + side
of the coil, wire from the - side of the coil to the power source wire of the
pertronix unit it will work.
Coil and Pertronix unit is energized with the switch on and de-energized with the switch off.
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 09-17-2021, 11:37 AM   #5
rotorwrench
rotorwrench's Avatar
Original pop out, No. It just wouldn't be practical. Modern switch that has a pop out feature, yes but it should be switching the power line to the hot side of the coil and not the hall effect module in the distributor.
