Old 12-06-2020, 06:47 PM   #1
Bob from Northport
Bob from Northport's Avatar
Default AA truck wiring question
Anyone know if they make a wiring harness that is made for a AA Truck/flatbed??
Or do we make the wiring longer for the rear of the truck???
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 12-06-2020, 07:10 PM   #2
wmarcy528
Default Re: AA truck wiring question
Rhode Island Wiring
http://www.riwire.com/
wmarcy528 is offline   Reply With Quote
Old 12-06-2020, 08:04 PM   #3
Bob C
There is some information on page E-16 and E-17 of the Standards.
Old 12-06-2020, 08:12 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bob, check your text messages.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-06-2020, 08:40 PM   #5
jb-ob
Bob,
Have the correct one made by Mr. Tyree Harris (804) 556-5200.
jb
jb-ob is offline   Reply With Quote
Old 12-07-2020, 10:18 AM   #6
Neil Wilson
Neil Wilson's Avatar
Bob,
The tail lamp wiring assembly is unique for the AA. There were seven variations of this assembly which depended on the month/year and makeup of the AA.
Information YOU need to know about your AA in order to get the correct wiring harness:
·Cowl Lamps being used? Yes or No (affects head lamp wiring harness)
·Head lamp design being used? (affects head lamp wiring harness)
’27 – early ’29 - fluted lens head lamps (has only one bulb – head/parking)
’29 – production end - TwoLite head lamps with two bulbs (head high/low bulb and separate parking bulb)
·Tail lamp design being used? – drum style or teacup style tail lamp (affects tail lamp wiring length)
·For drum style tail lamp – tail lamp bracket being used? (affects tail lamp wiring length)
·For fluted lens head lamps and drum style tail lamp – lighting switch being used? (affects tail lamp wiring length and connections)
·For 1931 AA131 – frame length? Specify 181-5/16” long frame or not (affects tail lamp wiring length)
·For AA157 - Extension wire assembly is required
The correct harness can be ordered from:
Chris Olsen – cell 541-410-8929
Bauer Electronics – Class Tech 541-389-6339
62935 Layton Ave.
Bend, OR 97701
[email protected]
The above contact information was correct as of 2/8/2011.
There is an article in the April 2011 Double A'er newsletter regarding AA Lamps and Wiring. This Double A'er can be ordered (see https://aafords.com/c/nl/#pn)
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 12-07-2020, 12:31 PM   #7
brito36
Tyree Harris can make you an exact copy of your harness. I have purchased several harnesses including one for my 1929 AA Stake Bed truck. Was very satisfied....
brito36 is offline   Reply With Quote
Old 12-07-2020, 03:18 PM   #8
shew01
shew01's Avatar
Tyree does good work. I bought a car he restored a while back.
shew01 is offline   Reply With Quote
Old 12-07-2020, 06:18 PM   #9
CarlG
CarlG's Avatar
Sacramento Vintage Ford
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
