03-22-2020, 01:12 PM | #1 |
Well...this ain't good
What a fabulous day here in central Florida for drive in the coupe. Or so I thought. Got about 6 miles from the house when I heard a pretty loud BANG! then some godawful noise. I thought maybe I had blown a tire. Nope.
Blew the plug clean out of the head. I knew these Eddie Meyer heads were a little sketchy when I bought the car. I guess they are REALLY sketchy now. They may become wall hangers after I see just how much corrosion there is.
Do I look like I have a plan B? |
03-22-2020, 01:37 PM | #2 |
Re: Well...this ain't good
Can´t really blame a stripped plug thread on corrosion...
Put in a timesert thread insert and be back on the road in notime |
03-22-2020, 01:42 PM | #3 |
It's called cylinder deactivation, Caddy used it on their 4-6-8 motors lol.
I fixed a Briggs & Stratton lawnmower with an insert, worked for years until I wore it out. |
03-22-2020, 02:15 PM | #4 |
I have repaired these with "Heli-Coils" and have had no problems. From everything I have heard, "Time-Serts" are superior. You may be all right, most of the stripped threads on spark plugs I experienced have been the result of crap not cleaned out and a large Flex-Handle.
03-22-2020, 02:22 PM | #5 |
Hoping you were able to "limp" it home?
03-22-2020, 03:13 PM | #6 |
03-22-2020, 03:18 PM | #7 |
03-22-2020, 04:40 PM | #8 |
Were the threads actually stripped? Could it have been that the plug was loose?
03-22-2020, 04:51 PM | #9 |
all used aluminum heads are subject to do that, last set I put on had 4 bad or suspect plug threads so I did all 8 with inserts to keep from what happened to you
03-22-2020, 04:53 PM | #10 |
Let the Flathead fun continue. Drive/Fix/Repeat. Sometimes it's Buy/Fix/Repeat. Pretty sure a cuss nd a band-aid has to be in there somewhere.
Heard, is it only the head/plug, did the hood escape damage? Sweet looking ride!
03-22-2020, 05:12 PM | #11 |
Thanks for the encouragement guys. No damage otherwise. Had a bunch of folks stop to help. Then I realized they were just wanting to see the car which was cool with me.
And no, I wasn't suggesting corrosion caused this. I should have clarified that I suspect there is corrosion other places.
03-22-2020, 05:13 PM | #12 |
Sorry to hear of your trouble.
Nice 3 window, by the way. Hope you're able to get her up and running. I wish I had the weather your having today to go for a cruise. Another month.....maybe.. |
03-22-2020, 05:22 PM | #13 |
As others have pointed out, I wouldn't hesitate in using Heli-Coils or other makes of thread repair system. If you aren't comfortable doing it, a machine shop can easily do the job for you.
03-22-2020, 05:49 PM | #14 |
Another brand that I don't already see mentioned.... KD
I've used, with good results. Only problem is, when you later want to remove the plug, the insert will also come out. And, I'm sure you already know, only remove plugs from aluminum heads, cold, like overnight cold, stone cold. Keensert |
03-22-2020, 06:01 PM | #15 |
welcome to the world of alloy heads not many get looked after like they should but the majority survive ,there tougher than they look. not many actualy torque plugs when fitting them less actually use an antisize and even lessactualy wait till their cold . [ i can imagine trying to tell a customer they have ti loose their car overnight just so i can change the plugs : let me know how that works out: just repair the thread and keep on enjoying your ride
03-22-2020, 07:06 PM | #16 | |
03-22-2020, 07:28 PM | #17 |
I never heard of leaving it to go cold. I'll try and follow that in the future. Never used anti-seize either! You learn something new every day.
Mart. |
03-22-2020, 09:12 PM | #18 |
Thats a easy in the car fix.
That V10 ford had for awhile were good for the same issue and a lot hard to get to. I like the nickle-ease supposed to be good for higher temperature. |
03-22-2020, 10:40 PM | #19 |
Glad the problem you encountered has a fairly easy solution. I had an outboard motor do the same thing and wondered what the explosion was.
03-23-2020, 02:05 AM | #20 | |
Man, some guys will do anything to get their car noticed on the internet...…so, let me help! DD The other side of Heard's really cool l'il 3-window! The bottom end ain't too shabby, either! ……. |
