Old 03-09-2020, 02:32 PM   #1
Doug
Default 1951 Ford Club Coupe Gas Tank Replacement
Getting ready to replace the gas tank in my 1951 Ford Club Coupe.
Looked at Shoebox Central website. Their replacement tank requires
a 5 screw hole sending unit. The original tank & sending unit has 6
screw holes. They offer both sending units however, disregarding the
number of screw holes in each, the 2 units are a TOTALLY Different
design/style from each other. ( Note: another vendor offers an adapter
plate to mount the 6 screw unit to the 5 screw tank)
Question: Anyone have knowledge/experience as to which design/style
sending unit is the better of the two? Thanks
Doug is offline   Reply With Quote
Old 03-09-2020, 03:18 PM   #2
estout81
Default Re: 1951 Ford Club Coupe Gas Tank Replacement
I used one of their tanks with the five screw sending unit. Installed sending unit as per their instructions. Worked good up to about 3/8's of a tank then went to full. Not accurate at all! Does keep you from running out of gas so, I guess that is a good thing. About all we can expect in these days. This was a '51 Ford.
estout81 is offline   Reply With Quote
Old 03-09-2020, 08:09 PM   #3
TJ
TJ's Avatar
Make a pattern of the 5 hole unit and transfer it to your old unit and re-drill the holes.
Old 03-09-2020, 09:05 PM   #4
Emmit51
Emmit51's Avatar
I was looking into this earlier when thinking of replacing the tank on my 51 fordor. The problem is the diameter of the original king seely unit is bigger than the hole in the repop tank. To use the original sender, you need to make a bigger hole in the new tank. For this reason, I’m in the process of reconditioning my old tank to use the original sender.
Emmit51 is offline   Reply With Quote
Old 03-10-2020, 07:41 AM   #5
flatford8
flatford8's Avatar
I’m using the five in a ‘50.... It’s accurate and works well... I wish the repop tanks had the drain plug..... I’m going the same route in a’51.... tank and the sender from Shoebox-Central....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
