Old 02-19-2019, 02:41 PM   #1
walter123
Question 53 Merc head bolt
Where can I puchase a head bolt that goes on the power steering bracket ? Its a little longer than the others. Don't know exact length, bolt missing. TU
walter123 is offline   Reply With Quote
Old 02-19-2019, 02:48 PM   #2
leon bee
Default Re: 53 Merc head bolt
If you don't find one around there, I got a used one you can have- pretty good condition off a 53 Merc engine.
leon bee is offline   Reply With Quote
Old 02-19-2019, 03:10 PM   #3
walter123
Thanks Leon, lets see what turns up. W
Old 02-19-2019, 03:49 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Seeing as you only have one missing the other one is the same length.
Anyway the parts call out is for (2) 7/16"-14 x 3 5/32" long. plus flat washers.
It may be possible to shorten a 3 1/2" long grade 8 bolt that can be obtained from most hardware stores as well as Home depot.
Old 02-19-2019, 03:59 PM   #5
Merc Cruzer
Merc Cruzer's Avatar
One more point of reference:
Merc Cruzer is offline   Reply With Quote
Old 02-23-2019, 04:29 PM   #6
walter123
Thanks for the info
Old 02-23-2019, 04:30 PM   #7
walter123
Thank you. W
