Old 07-05-2011, 09:44 AM   #1
walter123
Arrow 53 Merc caster camber specs
My tires are wearing on the outside and I am looking for some specs to give my mech. Thanks Walter123. I forgot to mention, the tires are radials...
walter123 is offline   Reply With Quote
Old 07-05-2011, 10:52 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 53 Merc caster camber specs
Check this out----
http://www.secondchancegarage.com/public/422.cfm
Old 07-05-2011, 01:56 PM   #3
ford1
prefered caster - 3/4 degrees, prefered camber +3/8 degree, prefered tow in 3/32 to 5/32"
ford1 is offline   Reply With Quote
Old 07-05-2011, 03:40 PM   #4
52merc
52merc's Avatar
mine are wearing on the inside edge is that toe out ??
52merc is offline   Reply With Quote
Old 07-05-2011, 05:02 PM   #5
ford1
could be or you camber is out making the front end run on the inside of the tires, check the easy stuff first check toe in and the toe out
