Old 01-17-2021, 03:44 PM   #21
JSeery
JSeery's Avatar
Default Re: Correct replacement for Fram C181-A?
If it was me, think I would take the filter I had to a parts store and compare the length to some other filters from different sources. That would show you any differences.
Old 01-17-2021, 07:30 PM   #22
Ziggster
Thanks. I’ll drop by a couple of parts stores tomorrow to see what they might have.
Ziggster is offline   Reply With Quote
Old 01-18-2021, 06:40 PM   #23
Ross F-1
Ross F-1's Avatar
Canadian engines used some different filters. Attached is a pic of a taller Canadian bypass filter, but I don't know what element it needs. Looks like OP's. (It's not the full-flow Canadian)
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 01-18-2021, 09:02 PM   #24
RalphG
RalphG's Avatar
That filter in your photo is like the one I have on the 49 Mercury truck. Taller than the cars.
RalphG is offline   Reply With Quote
Old 01-19-2021, 10:22 AM   #25
Ziggster
No customer service at RockAuto, so explained what the issue was (on-line return), and received a store credit. Interestingly, the C4P filter is no longer listed at all, and there is no stk available of the C4 filter. I checked multiple years (45-52) and various models, and all list the C4 amongst others. For example, they list the Wix 51006 (Napa 1006), and a search of that shows this info for the gasket.
Old 01-19-2021, 10:22 AM   #26
Ziggster
Some pics of my filter housing length.
Old 01-19-2021, 10:23 AM   #27
Ziggster
Inside dia of top cover.
Old 01-19-2021, 10:24 AM   #28
Ziggster
My gasket diameter.
Old 01-19-2021, 10:27 AM   #29
Ziggster
So clearly, my gasket is about 1/8" smaller in dia than either that provided with the Fram C4P filter or the Wix 51006 filter. In some of the filter pics from RockAuto, I could see that some filters include multiple gaskets. I wonder if it is is for this reason. My filter housing cannot be that unique.
Old 01-19-2021, 10:28 AM   #30
Will D
Will D's Avatar
In Canada you should be able to get the C4 and C4P at Lordco. Bumper to bumper/Gilbert supply carry the WIX51006. The C4 has a metal top and bottom with full paper center section. The WIX is full metal case.
I was using the C4 but trying the WIX51006 today.
Will D is offline   Reply With Quote
Old 01-19-2021, 11:13 AM   #31
tubman
tubman's Avatar
I get my oil filters from NAPA. I just ask for one for a Ford tractor and I get the right one. (They know a lot about tractors, but not old cars.) I have never gotten one that didn't come with two gaskets of different sizes.
Old 01-19-2021, 11:40 AM   #32
cas3
the only thing that matters is that it fits the tube in the center. after that you can shim it to length with a short piece of pipe or big spring like an old valve spring for example
Old 01-19-2021, 12:10 PM   #33
Bob C
Here is a picture of the NAPA 1006 (Wix 51006) filter.
Comes with two gaskets, 4.3" and 4.736". The filter
is 5" tall.
File Type: jpg Screen Shot 2021-01-19 at 9.07.18 AM.jpg (12.1 KB, 4 views)
Bob C is online now   Reply With Quote
Old 01-19-2021, 12:16 PM   #34
Ziggster
Yep, it fits the center tube snugly, and may require a small shim, but not sure how much pressure there should be on the spring because as is, there is no pressure when the top cover is tightened all the way down. Old gasket should be fine, but I will still look for the correct filter/gasket tomorrow when I head back into town. Never thought finding the correct filter would be this much work. Seems like same issue looking for the correct wide belt. Oy vey....
Old 01-19-2021, 12:19 PM   #35
Ziggster
is 5" tall.
Great. I'll order one tomorrow from either Napa or CarQuest.
Old 01-19-2021, 02:17 PM   #36
Aarongriffey
In the first place, you NEVER use a Fram oil filter. Never!
They are made cheaply, do not filter the oil good enough.
Google Fram oil filters on the internet. There are sites that show how poorly made they are.
I have seen signs in dealer service departments warning customers to not use Fram oil filters in their cars.
Aarongriffey is offline   Reply With Quote
Old 01-20-2021, 02:09 PM   #37
Ziggster
Ordered the Wix filter (P/N 51006). Will use it and resuse the original gasket if needed.
Old 01-21-2021, 04:02 PM   #38
Ziggster
Picked up a new filter from CarQuest, was expecting a Wix, but got their brand (P/N 85006). It's made in the USA as is the Fram, but it has an all aluminum pre-filter screen vs the paper screen on the Fram. It also has raised embossed sections on each each of the filter which I think is better, especially at the top since the spring should have something solid to rest upon vs the rubber grommet on the Fram filter. Also, the actual body is slightly longer (4 13/16" vs 4.5"). It came with two gaskets, both being larger than mine, but surprisingly, the smaller of the two actually fit nicely into my top cover. Only thing I'm rather concerned about with the CarQuest filter are the open seems where the two ends pieces meet the pre-filter screen. I'm guessing that the ends of the filter element are sealed with some type of glue/sealant and do not rely on the mechanical joint for sealing.
Old 01-21-2021, 04:03 PM   #39
Ziggster
Embossed section.
Old 01-21-2021, 04:04 PM   #40
Ziggster
Gaskets. The orig on the bottom.
