Old 03-05-2019, 07:37 AM   #1
walter123
Default 6 volt fuel pump?
what electric fuel pump will work best on my 1953 Mercury stock engine? I looked on Summit Racing and Airtex e8902 looked good, but was not for my car
walter123 is offline   Reply With Quote
Old 03-05-2019, 07:49 AM   #2
slowforty
slowforty's Avatar
Default Re: 6 volt fuel pump?
Rock Auto has 6 volt Airtex. But i would use a Carter. Any decent auto store can order it
slowforty is offline   Reply With Quote
Old 03-05-2019, 11:01 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
I don't know why the Airtex E8902 wouldn't work on your car. Works fine on my 8BA.
Pat/Ohio is offline   Reply With Quote
Old 03-05-2019, 11:51 AM   #4
Merc Cruzer
Merc Cruzer's Avatar
This 6 volt Airtex E8902 has been in my stock 53' Merc for 7 years now and has performed flawlessly. I turn it on for a few seconds befor starting the car, after it has sat for an extended period of time. I also turn it on when the car vapor locks, after sitting on a hot day or while driving, and it clears the system immediately.
Now I look like a hoarder, I still have the box it came it.
Merc Cruzer is offline   Reply With Quote
Old 03-05-2019, 12:21 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Originally Posted by Merc Cruzer View Post
This Airtex E8902 has been in my stock 53' Merc for 7 years now and has performed flawlessly.
That's what I bought to use on my '35 fordor sedan in 2013 before doing a cross country trip. I carried it as a backup to my mechanical pump, but never needed to use it. It's still in with the other spare parts I carry :-)
John
Old 03-05-2019, 12:43 PM   #6
supereal
supereal's Avatar
I have had a six volt Airtex pump on my '47 for over 20 years with no problems. I got mine from C&G. They used to come with a filter included, but is now must be bought as an add-on. If you have an inline filter between the tank and the pump, you probably don't need the accessory. I use mine to refill the carb after the car has sat for along time. In the hottest part of the year, it can come in handy if the system blows a bubble on a hard pull.
supereal is offline   Reply With Quote
Old 03-05-2019, 05:53 PM   #7
slowforty
slowforty's Avatar
Rock Auto may have the Cheapest Price around.
Old 03-06-2019, 06:11 PM   #8
walter123
Thanks to all for the information. when I went to the Summit Racing site and brought up the e8902 it said up in the left hand corner not for the 53 merc. That's why I asked. It had every thing I was looking for 6volt and low psi. Thanks again.
Old 03-07-2019, 12:24 PM   #9
Robz51
Robz51's Avatar
I have a carter pump on my 52 but it's mounted like MercCruiser has his. Yes, it will fit your car.
Rob
Robz51 is offline   Reply With Quote
