Old 03-04-2011, 01:14 PM   #1
walter123
Default 53 Merc electric fuel pump
I am installing a electric fuel pump on a 53 merc hd tp. Where is the best place for the pump to go and also where would the regulator go. There is not a lot of room under the hood for the regulator. If someone has intalled a pump on this car I would appreciate the help. Thank s Walter123
walter123 is offline   Reply With Quote
Old 03-04-2011, 01:18 PM   #2
Chris Nelson
Chris Nelson's Avatar
Default Re: 53 Merc electric fuel pump
Mount the pump by the gas tank, as low as you can. The regulator can be mounted on the firewall wherever it is convenient. If you are using both the electric pump and the mechanical pump, it should be between the last pump and the carb.
Chris Nelson is offline   Reply With Quote
Old 03-04-2011, 01:27 PM   #3
walter123
Thanks Chris
Old 03-04-2011, 03:01 PM   #4
proxie35
proxie35's Avatar
Walter, We would sure love to have & you Merc. at the 49-53-Ford-Mercury Convention. June 1-4 in Pigeon Forge Tn. Go the Shoebox group here at the
barn for details. Sherrel
proxie35 is offline   Reply With Quote
