Old 04-02-2020, 11:00 AM   #1
burner31
burner31's Avatar
Default Cracked head- pic
Two cracks from bolt hole to water jacket, nothing to the cylinders
Is this head any good to use?
Your opinion matters.
Keith
Shawnee OK
'31 SW 160-B
Old 04-02-2020, 11:05 AM   #2
rocket1
Default Re: Cracked head- pic
I would look for a better one,bought them for $10.00.
rocket1 is offline   Reply With Quote
Old 04-02-2020, 11:13 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
Time to replace with a higher compression head , now that the cracked original head is removed .
Old 04-02-2020, 11:28 AM   #4
burner31
burner31's Avatar
Which head would be better for me, the high dollar 6/1 or the 5.5/1
Keep in mind I'm not racing or touring, just cruising around town checking out the old women, why old women...because they tire easily.
Keith
Shawnee OK
'31 SW 160-B
Old 04-02-2020, 03:29 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
Snyder's charges the same for both the 5.5 and 6.0.
Old 04-02-2020, 04:23 PM   #6
Russ/40
Russ/40's Avatar
IMO, you'd be nuts to buy the 5.5 when the 6 is the same price. I agree with the few above, that your head is usable. But, with the opportunity the head being off, I'd go for the 6:1 head. Yours is a good candidate to be one with weeping problems. Your water holes show a lot of rust.
Old 04-03-2020, 09:33 AM   #7
SSsssteamer
SSsssteamer's Avatar
Ditto. Potential problems from the cracks.
SSsssteamer is offline   Reply With Quote
Old 04-02-2020, 11:35 AM   #8
Purdy Swoft
I'm not racing either but I would prefer the 6 to 1 head for the extra power for the hills and passing when necessary .
Old 04-02-2020, 11:59 AM   #9
chrs1961815
chrs1961815's Avatar
You might as well go for the 6:1, more bang for your buck. Not a lot of people buy the 5:5 anymore.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-02-2020, 11:58 AM   #10
1930artdeco
1930artdeco's Avatar
I use the 5.5 on my car and I have a Townsedan. It works great even in the mountains.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-02-2020, 12:00 PM   #11
Jim Brierley
Yours is probably OK to use as-is. This is a common place for them to crack, it is not in a area where high pressure is found.
Old 04-02-2020, 12:45 PM   #12
Dave in MN
Dave in MN's Avatar
I agree.
Dave in MN is offline   Reply With Quote
Old 04-02-2020, 01:19 PM   #13
kenparker
kenparker's Avatar
I agree with Jim and Dave. Would not hurt though to use some sealant around the stud just below the head nut.
kenparker is offline   Reply With Quote
Old 04-02-2020, 03:07 PM   #14
Big hammer
Higher compression head to get away from older ladies husbands ! I would go with the pros on reusing the head, if money is a problem.
get a bigger hammer tap done
Old 04-02-2020, 03:16 PM   #15
jak
this is what i have gleaned from years in the parts business. People always call and ask which head should i put on my car. The first question i ask is what is the babbit like on the bottom end. If you put one of those heads on and the babbit isn't good you will beat the babbit. I cannot tell you how many guys i talk to purchase either the 5.5 or 6:1 head and a couple of weeks later call and order a bunch of engine parts because they beat the babbit out of the bottom end.
jak is offline   Reply With Quote
Old 04-02-2020, 03:22 PM   #16
J Franklin
J Franklin's Avatar
That is an early head on a later block. You could re-use it or find another original head, or as others have said if you have good bearings buy a new head.
Old 04-02-2020, 08:16 PM   #17
w.michael
w.michael's Avatar
I had one cracked in the same location and had the same questions you have. I finally decided that the crack was where the compression leak into the water jacket was occurring--and I know it does not look like that is possible. But I really did not find any other place the head gasket was leaking.
I ultimately did not try to re-install my cracked head. I bought a stock, used head from James Rogers at Dreamwerks, cleaned, magnafluxed, re-surfaced and ready to paint and install for a very reasonable price. Best decision in my situation.
See the old thread:
https://www.fordbarn.com/forum/showthread.php?t=167112
W. Michael
w.michael is offline   Reply With Quote
Old 04-02-2020, 09:55 PM   #18
Jack Shaft
Yes that head you show is fine to use,for grins I use my thumb and push at little sealant in the crack and wipe it off flush with the head...The snyder 5.5 is a copy of Ford engineerings heart shaped combustion chamber used on the 'police' head in 1931..the actual difference in the seat of the pants from 5.5 to 6 to 1 is negligible,especially if everything else is stock..
Old 04-03-2020, 08:07 AM   #19
old31
I originally bought the Snyders 5.5 head and installed it. I was so impressed with the performance, better hill climbing, faster pickup, that I sold it and installed the Snyder 6.1.
I am very happy I changed it out. There was a noticeable difference from the 5.5 vs 6.1. Although not as noticeable a change as was the original 4.2 to 5.5 swap.
I can not imagine what a 7.1 head would be like. If someone made one that looked original i would go for it.
old31 is offline   Reply With Quote
Old 04-03-2020, 08:37 AM   #20
Jack Shaft
Got a period cast iron 7 to 1 head..it says 'winfield' on it..runs good.
Tod Buttermore is making them now,brand new
