Old 03-07-2020, 08:59 PM   #1
uncle buck
uncle buck's Avatar
Default Speedo changer for Columbia 2 Speed
I am not familiar with these speedo changers. I got this with some 42-48 Columbia parts. I have heard big trucks also used them but they operate
backwards? I imagine that it probably needs to be disassembled and lubed
and am wondering if and how to change it from truck to car style if possible?
Also are new bellows / diaphragms available?
Thanks
uncle buck is offline   Reply With Quote
Old 03-07-2020, 09:02 PM   #2
uncle buck
uncle buck's Avatar
Default Re: Speedo changer for Columbia 2 Speed
Try again
File Type: jpg 0CFC07A9-248C-4BF1-8149-9D4B24D88607.jpg (76.5 KB, 107 views)
File Type: jpeg B358DEF9-D3C4-4F19-982A-AFD11012DAE1.jpeg (117.7 KB, 98 views)
Old 03-08-2020, 09:58 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
The truck ones used only 1 diaphram with spring return---same as truck 2 speed rear, the car columbia used 2 diaphrams, I think the whole innards have to be flipped over so it shifts between direct and turning the speedo faster
Old 03-08-2020, 11:14 AM   #4
uncle buck
uncle buck's Avatar
Does this picture help identify this one
File Type: jpeg 2AE07451-6924-4C97-9D65-E48AE2E2A32B.jpeg (109.4 KB, 35 views)
Old 03-08-2020, 04:55 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
it's for truck -one vacuum diaphram, spring loaded return, most common on 42-47 big trucks--some had different ends or bushings in the end to adapt in later years, plus a little square drive connecter ----
Old 03-08-2020, 08:18 PM   #6
Bored&Stroked
Bored&Stroked's Avatar
I think the real issue will be the diaphragm . . . if it is shot (and it probably is), then you'll need to find some sort of replacement. This is the same issue with the dual-diaphragm Columbia units.
Hey - anybody know of a new/replacement that can be used in the dual-diaphragm Columbia setup? Inquiring minds need to know! LOL
Old 03-09-2020, 09:15 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
The car changer has 2 diaphragms, the other are from big trucks, some are designed to fit only on the back of speedometer, others can go in between sections of cables
I have reground pliers jaws to open the crimps and replace diaphragm, sometimes re riveting the operating shaft, sometimes drilling and tapping for nut or small screw
Old 03-09-2020, 09:23 AM   #8
RobR'35
RobR'35's Avatar
That's pretty cool. I've never heard of anyone tearing into the diaphragms and make repairs.
By chance do u have any photos?
RobR'35 is offline   Reply With Quote
Old 03-09-2020, 10:49 AM   #9
uncle buck
uncle buck's Avatar
That's good info. I have heard in the past that you can use the big truck unit by flipping the gears? Is that true?
Old 03-09-2020, 11:02 AM   #10
deuce_roadster
deuce_roadster's Avatar
Yes, Gary Duff switched the truck ones for my 2 Columbia units for my 40s. Mine don't have any diaphragm. I believe he takes the gears off their shafts and switches them. You might talk to him.
There is a picture of the Columbia controls in my 40 coupe album.
Old 03-09-2020, 02:01 PM   #11
uncle buck
uncle buck's Avatar
Thanks Mike, My neighbor has a survivor 40 deluxe coupe with everything stock and his doesn't work so we are trying to figure these out.
Old 03-09-2020, 02:48 PM   #12
RobR'35
RobR'35's Avatar
Found this in some of my records.
Maybe it'll help.
Sent from my SM-G955U using Tapatalk
Old 03-09-2020, 05:03 PM   #13
motordr
Sure, get some NOS choke diaphragms and modify them to fit, that is what I did and works like a charm.
motordr is offline   Reply With Quote
Old 03-09-2020, 10:28 PM   #14
Bored&Stroked
Would you happen to know what year car and/or type of carb? That is a great idea - never thought of it - thanks! Any help you can give to point me in the right direction, just getting ready to rebuild a Columbia for my 32.
Old 03-10-2020, 07:53 AM   #15
motordr
Any early seventies GM Rochester 2-barrel diaphragm would work, will see if I can find the part number for you. Requires some cutting, bending and mig welding to keep heat from damaging the diaphragm.
Old 03-10-2020, 12:12 PM   #16
motordr
The choke pull-off I used is an aftermarket product CP452 by Avatar AIP Company. Listed applications: chev 1975-73 R1 250 engine, so the six cylinders. I would think that others would be adaptable too, just try to get two the same.
Old 03-10-2020, 02:25 PM   #17
G.M.
You are on the right path. I used 3 or 4 of these but it was 40 years ago.
I remember machining an adaptor and I think it was mounted backwards.
Can't remember any more. G.M.
www.fordcollector.com
Old 03-10-2020, 07:31 PM   #18
Bored&Stroked
Thanks a bunch - that is exactly what I'll pickup - or something similar. Again, great idea to solve the problem.
Old 03-15-2020, 01:36 PM   #19
Ggmac
I was just cleaning out my 40' container of old car parts and found a possible diaphragm. I've never had a Columbia or know anything about the diaphragm part but after looking at the picture , this may work . Do you have the dia and aprx travel . The parts I've put aside are from 1970-80s air cleaners on carbureted engines . It's the vacuum control on the air cleaner that controls the flapper in the inlet .
Hope it helps .
Ggmac is offline   Reply With Quote
