07-06-2018, 01:41 PM | #1 |
running issue
During Summer when it was hot I noticed that when the temperature got up on my car after a while, the engine started to run rough like a "bag of well kicked assholes".
Now winter is here ( we can drive our cars all year round in our temperate climate) I find the car runs a lot better without this issue. I also notice the temperature gauge does not peg as high. I have a good Skip rebuilt coil on it. Any ideas what I should look at before Spring arrives? GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
07-06-2018, 02:46 PM | #2 |
Re: running issue
Do you have that crappy ethanol gas over there? Or down there as it may be? We have it all over here in the states and it will boil at your fuel pump when temps are 80 degree plus.
07-06-2018, 04:47 PM | #3 |
Re: running issue
It is often suggested that the condenser could cause those symptoms.
07-06-2018, 08:11 PM | #4 | |
Re: running issue
have a full flow of gas. G.M.
www.fordcollector.com |
07-13-2018, 01:23 PM | #5 |
Re: running issue
Thanks folks.
GB
07-14-2018, 01:02 AM | #6 | |
Re: running issue
07-15-2018, 03:58 AM | #7 |
Re: running issue
not trying to be funny but what is your average temps summer + winter and what temps does your engine run at as in my experience your engine should run at same temp approx summer or winter if your cooling system is working correctly just may take a bit longer to warm up in winter large variations in tempetature can cause no end of problems and is often overlooked when trying to trouble shoot
07-15-2018, 06:22 PM | #8 |
Re: running issue
You might not have a running hot problem, but a running rich problem, which becomes more obvious as it gets hotter.
Purely a guess. Mart. |
07-16-2018, 07:46 AM | #9 |
Re: running issue
thats where i was headed but trying to get some more specific information before i jumped in with that one
07-17-2018, 01:33 AM | #10 |
Re: running issue
Mart / Aussie merc. Thanks for your input I'll look at this.
GB
07-22-2018, 05:22 AM | #11 |
Re: running issue
just wondering on how you went
