Old 08-18-2013, 03:42 PM   #1
37fatfender
37fatfender's Avatar
Default Edelbrock 4 Barrell
If anyone is using a Edelbrock 4 bbl on the flathead I would be interested if you have rejetted the carb or what other tuning you have done. I have mine on a 255 ci motor with a Schnieder cam. The plugs are always black, so I went to smaller jets per Edelbrocks tuning chart...still rich. I live at 2000 ft above sea level and frequently go over 5000. How does altitude affect jetting? Higher the altitude smaller jets ?
37fatfender is offline   Reply With Quote
Old 08-18-2013, 04:02 PM   #2
52merc
52merc's Avatar
Default Re: Edelbrock 4 Barrell
what size edelbrock you running a 500 or 650
trev,, whats life "TOUGH" whats tough ' LIFE"
52merc is offline   Reply With Quote
Old 08-18-2013, 04:58 PM   #3
52merc
52merc's Avatar
richard in fl runs a 500 on a 276ci engine he has not changed the jets but has played around with ignition timing he gets great milage,i have however have a500 on my 271ci ive gone down 2 jets sizes also took out the main jets and put them into the vac secondary hope this helps
Old 08-18-2013, 05:02 PM   #4
37fatfender
I have the 500 cfm carb, gone done one size. Ignition is the MSD ready to run dizzy.
Old 08-18-2013, 06:46 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The altitude does make a difference . I'm sure an engineer type will chime in with the figures.
Old 08-18-2013, 06:53 PM   #6
Richard in Florida
Richard in Florida's Avatar
Originally Posted by 52merc View Post
richard in fl runs a 500 on a 276ci engine he has not changed the jets but has played around with ignition timing he gets great mileage.
As Trev said, I'm running a Performer 500 on my 276 with stock valves, an L100 cam, Red's headers, and various other touches.
Back when I was running a simple HEI module driven by a Chevy distributor converted to a magnetic trigger I was getting about 8.5 mpg with the stock Edelbrock setup.
After a lot of experimenting I ended up using Setup #11. I now run high 14 to high 15 A/Fs with occasional 16s in cruise. My mileage went up to 21.3 in my 3300 lb '53 Victoria with a 4.10 rear and .72 overdrive.
Richard in Florida is offline   Reply With Quote
Old 08-19-2013, 12:11 AM   #7
36rgtop
36rgtop's Avatar
Is that 21.3 MPG best highway MPG or best combined MPG (highway+city)?
36rgtop is offline   Reply With Quote
Old 08-19-2013, 09:08 AM   #8
Richard in Florida
That was 2/3 city (town) and 1/3 highway. You have to drive the 2/3 to get to the 1/3.
Old 08-19-2013, 09:48 AM   #9
37fatfender
Richard, What jets did you put in the secondary, if any change? Did you do any secondary tuning ? what plugs do you use? and their gap?
Old 08-19-2013, 09:49 AM   #10
36rgtop
36rgtop's Avatar
Thanks, then I can assume that's a little less around town and a little better on the highway.
Old 08-19-2013, 10:09 AM   #11
dude
dude's Avatar
Good base line would be to call Edelbrock tech. They are very helpfull. Might just save you some time and money.
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 08-19-2013, 10:56 AM   #12
Ol' Ron
Ol' Ron's Avatar
We've been tuning with a wide band AF meter. This also includes a vacuum advance curve as well as the Mechanical. Different engines require different settings to get this kind of economy. Also piston to head clearance is critical.
Old 08-19-2013, 04:39 PM   #13
Richard in Florida
Setup #11 uses the stock .065 x .052 metering rod; the main jets are changed from .086 to .083.
I didn't do any secondary tuning. When I floor it and the secondaries open, the A/F goes to 12s and 13s, which is good.
I run NGK F4 plugs gapped at .025 which is right for the flathead even though I'm running electronic ignition.
Old 08-19-2013, 04:55 PM   #14
Richard in Florida
Probably, but I didn't try to separate them.
That 21.3 mpg run was made with a 4.10 rear end. The next run should be interesting with the 3.54 I recently installed.
Setup #11 has proven to be the best blend of economy and performance for my car.
