12-10-2020, 04:15 PM | #21 |
Re: Gland rings
They install easy enough so they should be used. If the install was as difficult as putting socks on a rooster I would not bother since the benefit is probably minimal.
12-10-2020, 06:24 PM | #22 |
Gland rings
12-12-2020, 05:00 PM | #23 |
Re: Gland rings
UPDATE>>>>>I got # 1 & 4 to line up and results were great . Also , I used
UPDATE ......I used JB weld to fix the exhaust manifold and level it off . # 1 % 4 have gland rings lined up and it sounds quiet. Thanks to all jb |
12-13-2020, 05:08 AM | #24 |
Re: Gland rings
According to the SDS for JB weld extremeheat it is not an epoxy but a sodium silicate (water glass) putty containing steel fines. A single pack product containing water and finally set by heat after drying.
This makes sense because no epoxy can withstand more than about 260 deg C (500 deg F)and Extremeheat claims 1300 deg C (2372 deg F) which is white heat - way above red heat (about 550 deg C)! The downside is water glass is brittle and has poor adhesive properties. It is not "sticky" like epoxies SAJ in N Z |
12-14-2020, 08:37 AM | #25 | |
Re: Gland rings
12-14-2020, 12:32 PM | #26 |
Re: Gland rings
12-14-2020, 03:37 PM | #27 |
Re: Gland rings
Brent, I have not used JB weld Extremeheat. My comments are only from the view of an industrial chemist who has formulated similar products many years ago. And to correct the statements that it is an epoxy.
I currently have a Devcon silicate single pack product and another silicate paste containing steel fines on my shelves, I think called "liquid steel" or something. I used them only where supported from escape, as in sandwiched under a gasket etc , because they do not adhere and cling on when not restrained and have no flexibility to resist expansion and contraction with large temperature changes. Cured silicate glass is very brittle. I manufactured many well known silicate cracked-block additives in the 70's to add to radiator water. They could be a permanent fix if the crack was in a suitable place and compression was relieved in the cylinder in question until combustion heat from adjacent cylinders cured the silicate. In these cases the silicate was trapped and could not fall out of the crack. Epoxies have an inherent adhesive quality and flexibility (if properly formulated) that allow them to stay put in external cracks. None of the sodium silicate products I have tried are good at this in exposed cracks. That does not mean it is impossible, since new compounds are being devised every day. And again these are only my opinions. In my business my chemists and I I are always experimenting, observing and recording. Re-readiing the original posts and replies, I should add that Extremeheat should work well to level the block or manifold under the gasket and I was not criticising its use in this application. Only correcting that it is not an epoxy and I do not think it suitable where it can crack and "fall out" of exposed open repairs. SAJ in NZ Last edited by SAJ; 12-14-2020 at 03:43 PM. Reason: Added content after re reading posts |
12-14-2020, 03:54 PM | #28 |
Re: Gland rings
I see the advantage of using the gland rings to hold the manifold in correct alignment. However, if you cannot mount the gland rings due to a sagging manifold and the manifold is not cracked and very useable, is there any harm done to the block by not using the gland rings. In other words, is there any harm done trying to get a few more miles out of the manifold? Ed
12-14-2020, 04:36 PM | #29 | |
Re: Gland rings
