Old 05-15-2020, 09:55 PM   #1
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Fan Belt question for NZ Barners
I had a noise from the fan generator area and investigated and found my fan belt is torn. Do any of the the NZ barner have a local source for the big belt (Generator) on a 59a engine? or a part number for one that will fit?
thanks
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 05-15-2020, 10:50 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Fan Belt question for NZ Barners
thanks
GB
Graeme,
They are a B section. Have the sizes of the 2 belts on white board at home. Will post them here when I get home later in the day.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 05-15-2020, 11:03 PM   #3
Originally Posted by Phil Gillespie View Post
Graeme,
Phil NZ
Cool Phil been looking at Gates industrial B series from web search could be a 50 or 54 length look forward to your reply. Can get Gates belts on line from Bearing engineering supplies here in NZ
Old 05-15-2020, 11:51 PM   #4
flatheadmurre
flatheadmurre's Avatar
I use B52 if you want a stock looking belt.
BX52 is the cogged one with a bit better power transfer ratio.
The size can go up or down a bit depending on what shieve you have on the generator...but with the normar pulley for a 59AB the B52 works fine.
Old 05-16-2020, 01:31 AM   #5
Phil Gillespie
Just checked, I'm using a B50 on Genr and B34 on cooling fan.
I get mine from an old style Engineering Workshop at Oxford. They still store them off hooks at wooden rafters.
Phil NZ
Old 05-16-2020, 03:11 AM   #6
great thanks Phil.
GB
Old 05-16-2020, 04:24 AM   #7
Thanks for your help
