12-31-2020, 07:09 PM | #1 |
Head bolt sealant
What have you guys found to be the best sealant for the head bolts to block on a 21 stud. I tried thread sealant paste but it didn't work. Thx and Happy New Year
12-31-2020, 07:25 PM | #2 |
Re: Head bolt sealant
I have used 3m weatherstrip adhesive for longer than I can remember on dozens of not hundreds is engines to include flatheads, small & bb Chevy. Never a leak or issue.
12-31-2020, 07:29 PM | #3 |
Permatex no. 1
12-31-2020, 07:41 PM | #4 |
Thx. Pematex was my next option
12-31-2020, 07:44 PM | #5 |
Permatex #2 on headbolts.
12-31-2020, 07:48 PM | #6 |
X2 on number 2
01-01-2021, 08:30 AM | #7 |
Permatex Thread Sealer part #80632 Available on Amazon in both the 4oz jar and 6ml tube.
This is a Teflon product that I have found seals well and does not harden. . . Chap |
01-01-2021, 09:30 AM | #8 |
Buy at O'Reilly's. I have also used Non -hardening permatex as it works great also.
01-01-2021, 11:53 AM | #9 |
I used to use Aviation Permatex and just dip the threaded tips in the can but there are likely better sealers now days. This also keeps the bolt tips from corroding which allows for easier removal during maintenance.
01-01-2021, 12:47 PM | #10 |
01-01-2021, 01:54 PM | #11 |
I use ARP Teflon stud/thread sealant - comes in a tube.
https://www.jegs.com/i/ARP/070/100-9904/10002/-1 When I install the studs, I do not put water into the engine for at least a day - just to give it some time to seal the threads a bit. Also, I use a thread chaser (not a tap), on the block threads - to get as much rust and old crap out of them as possible. This method has worked for me on countless flatheads - with both studs and bolts. |
