09-30-2021, 06:15 AM | #1 |
Original 1939 Columbia two speed tag
09-30-2021, 06:33 AM | #2 |
Re: Original 1939 Columbia two speed tag
Thanks for posting. Original Columbia literature is rare.
09-30-2021, 11:00 AM | #3 |
Thanks for sharing!
09-30-2021, 12:13 PM | #4 |
"LUBRICATION INSTRUCTIONS – IMPORTANT With rear wheels off of floor fill rear axle through filler hole in Two-Speed Axle housing with 4½ Pints of standard Ford rear axle lubricant. (DO NOT USE CUP GREASE ) Start motor, shift transmission into high, and Two-Speed Axle control valve in high, depress clutch pedal to floor board, which completes shift in rear axle. Allow clutch pedal to return and run five minutes in this position. This is for the purpose of circulating oil through the entire Two-Speed Axle Unit. Next remove jack and with wheels on floor, BE SURE to refill axle to new oil level plug." |
