Old 07-06-2021, 08:07 PM   #1
conifermountains
Default 1947 Coupe wiper motor
This is my first time posting and I'm sure not my last on Ford Barn.
If anybody has removed a vacuum motor from a 47 coupe, I sure would like some help before I dig into it. The switch in the motor does not reverse the direction if that is suppose to be how it works. I've tried running miracle fluid through the motor but still you have to turn the control knob off and on to get the wipers to travel back and forth. I can't figure out how to disconnect the arms from the motor.
Phil
conifermountains is offline   Reply With Quote
Old 07-06-2021, 10:28 PM   #2
fordor41
fordor41's Avatar
Default Re: 1947 Coupe wiper motor
there is a clip on each wiper arm link to the vac. motor,with a spring between the two clips on pins. the holes in the clips are key shaped. the spring between the clips pull the clips together. pull the clip away from the pin(outward) and it should come off. repeat for other side. note which wiper arm link goes to which pin as if you don't the wipers will operate upside down(try to go down instead of sweeping across the glass). Ebay has a pic of the spring clip on a vac. motor. search 1947 ford wiper
fordor41 is offline   Reply With Quote
Old 07-07-2021, 08:12 AM   #3
Automotive Stud
Automotive Stud's Avatar
The motor is pretty simple to remove. Like Fordor41 said the spring clips come off to remove the arms and then two bolts remove the motor. There is a cover that comes off on the front of the motor, you'll see a cam in there that should flick back and fourth to reverse the motor. It's probably dry, just add some light oil to make it work smoothly.
Automotive Stud is offline   Reply With Quote
Old 07-07-2021, 08:25 AM   #4
conifermountains
Thanks so much!
Old 07-07-2021, 09:01 PM   #5
51woodie
51woodie's Avatar
Here is some pics of the wiper motor from my '46 Coupe, that may be helpful.
As mentioned in a previous post, don't mix up the connection of the links.
51woodie is offline   Reply With Quote
Old 07-08-2021, 11:45 AM   #6
supereal
supereal's Avatar
There is a "flipper" in the wiper motor that reverses the motion. It has a spring that can break and fall out of place. These "Trico" wiper motors are simple. The usual faults are the seal on the paddle is hard and worn, and/or the gasket between the top and the body of the motor stops sealing. Most of us don't drive in the rain unless we got caught in a shower. The vacuum motors tend to be unreliable any way, and if you really need constant wipers, electric type is available at C&G: 800-266-0470
supereal is offline   Reply With Quote
