11-14-2016, 10:11 PM | #1 |
air cleaner for a 94 carb
I've been searching for an air cleaner assembly for a 94 carb. All I've found is a K & N at autozone. I would rather have a paper filter. Anyone have a suggestion?
11-14-2016, 10:48 PM | #2 |
Re: air cleaner for a 94 carb
If your looking for a aftermarket type air cleaner check out Speedway Motors. O'brien Truckers also has some nice air cleaners that use a fabric type filter that should breath better than a paper element.
11-14-2016, 11:28 PM | #3 |
I used K&N E-3330. Has lots of surface and doesn't look to bad. Had to make a special screw for extra height.
11-14-2016, 11:48 PM | #4 |
See if you can find a 55 air cleaner. however converting the 55 to a paper filter is a real pain. Think the filter I used was for a mini moke. The above might be easier.
11-15-2016, 07:36 AM | #5 |
I found that the small one seems to restrict the air flow too much. But I am running dual 94's and they may be fine on a single. |
