10-19-2015, 08:16 AM | #1 |
33-34 Brake/Clutch pedal assembly question
I am reassembling my 33 coupe and I have mounted the pedal assembly but there is a spring that attaches to the clutch pedal and I don't know where the other end attaches.
Can someone enlighten me? Thanks! Brad
Brad Williamson |
10-19-2015, 11:29 AM | #2 |
Re: 33-34 Brake/Clutch pedal assembly question
I believe it goes to the frame to keep the release bearing off the pressure plate
in the out position. Last edited by Flowmeister; 10-19-2015 at 12:08 PM. |
10-19-2015, 11:57 AM | #3 |
This photo might help
10-19-2015, 12:26 PM | #4 |
Brad , Spring pics look OK . The hole you need is above the pedal bracket directly behind the pin .
10-19-2015, 12:40 PM | #5 |
Thanks guys!
Looks like my pin is in backwards too which explains why I could not find the correct whole.
Brad Williamson |
10-19-2015, 01:52 PM | #6 |
10-19-2015, 02:15 PM | #7 |
Good info, that I needed also! THANKS!
10-19-2015, 02:31 PM | #8 |
I don't have one for the brake pedal. Thanks for the info Terry.
Brad Williamson |
