05-08-2014, 04:21 PM | #1 |
1956 2X4 INTAKE+AIR CLEANER/Carbs
Trying to find out rarity and value of what this combination. Will be able to take pics this weekend. Marked EDB-9 425-C. This belongs to a friend.
05-09-2014, 07:16 AM | #2 |
Re: 1956 2X4 INTAKE+AIR CLEANER/Carbs
That manifold is the 1956 unit and is much harder to find than the more common 1957 dual quad manifolds. The carbs should be list #1268's if they are the originals.
05-09-2014, 11:28 AM | #3 |
Thank you Ted. I will check the carb numbers and get some pics up this weekend.
05-09-2014, 11:29 AM | #4 | |
Another Ford Barner (oldmics) may chime in on this one. He has the most knowledge on the '56 set-ups of anyone I know. He has supplied me with some facts and Ford documents related to it. There were two set-ups offered over the counter at Ford and Merc dealers. I'm pretty positive that the only parts shared in the two set ups were the carbs (Holley List 1268's) as Mr. Eaton stated. The Mercury version was called M260, and not sure if the Ford version had a label. Seems like a separate engineering team worked on each kit. (Merc and Ford). I know one of the manifolds used was cast as ECZ-C and made by Edelbrock. I think Edelbrock also put the kits together (with Isky cams). I think they were E-2 cams. Both kits came with cyl. heads, cam, lifters, valve springs, fuel lines, linkage and two individual air cleaners (not one like the 1957 set-up had). Like I said, only the carbs were shared by each kit. even the air cleaners were different. I won't say more, for fear of getting some facts wrong. Maybe Oldmics will comment. I know he has explained it all before. Sal |
05-09-2014, 04:14 PM | #5 |
Didn't the Merc's use Carters for carbs?
05-09-2014, 06:00 PM | #6 |
Timmy's page has some good pictures and info on Manifolds. http://m571.com/yblock/intake.htm |
05-09-2014, 07:57 PM | #7 | |
Carter WCFB's may have been used by certain people, but there is no factory documentation for it. Only documents show the Holley teapot 1268's in those kits for Mercury and Ford. The Carter carb manual also shows no such application for WCFB's, however the Holley manual does list a special carb for the 1956 set-ups. |
05-10-2014, 03:58 PM | #8 |
Intake and carbs for sale on Ebay now
05-10-2014, 06:56 PM | #9 |
05-10-2014, 10:09 PM | #10 |
310825496083
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic |
05-10-2014, 10:58 PM | #11 |
That is Grand Rapids Ohio and I am in Ontario Canada. Not the same one and this has an air cleaner too. I took pics today but will upload tomorrow. Not a big fan of Ebay. I have a Barner interested but it is my friends so I will be the piggy in the middle.
05-11-2014, 09:31 AM | #12 |
That intake has been on EBAY for quite a while. The intake is real 1956 dual quad kit, but the carbs are passenger car 1956 292 or 312 single 4 barrels. In that condition, carbs are worth maybe $50 each. Not sure about the intake, but looks way over priced to me.
05-11-2014, 08:30 PM | #13 |
Here are the pics. Note repaired corner on manifold.
05-11-2014, 08:40 PM | #14 |
Another
05-11-2014, 10:23 PM | #15 |
OK so why so secret about the listing number?
I'd like to have a chance to bid if it's on ebay.
05-11-2014, 10:23 PM | #16 |
Send me a photo Hightower. I am in Ontario.
05-12-2014, 01:10 AM | #17 |
05-12-2014, 05:10 AM | #18 |
That is correct.... It is not on Ebay. This is owned by a non computer friend. And I won't put anything on Ebay that I could sell face to face or to a Barner or HAMBER.
By the way, there is a gentleman wanting to buy this (a Barner) from my friend. I only asked about it originally to find info but I guess if somebody needs it he might sell. |
05-12-2014, 10:11 AM | #19 |
Whose intake and carbs are we talking about? It's not the OP's.
05-12-2014, 03:22 PM | #20 |
Sorry to hear the intake has been repaired. The Purolator air cleaner is worth something. The carbs and linkage are not correct, and there are a lot of fittings and pieces missing to handle 56 distributor with dual advance. That is the correct air cleaner and no, there was not an air cleaner on each carb. If you think it is difficult to get a 312 working with a 4000, load-0-matic distributor, and a dual diaphragm, quadruple the problem. The original kit worked on a 3 speed standard, or 3 speed overdrive and not automatic. If you want to put it on an automatic that you will have to rob parts from your 57 Ford kit that would handle automatics. As far as the air cleaner value is concerned, a 1957 Ford passenger nos 2x4 air cleaner sells for $1000.00, so this would be less
