08-03-2021, 02:07 PM | #1 |
Whatzit agian
Hate to keep asking but have stuff and don’t find a picture elsewhere.
Aluminum carb with windows in the bowl. Not a name or number on the outside |
08-03-2021, 02:53 PM | #2 |
Re: Whatzit agian
So much stuff, good and bad, was put out for the Model T Ford. You may never find a good answer but keep trying and you never know. Maybe it was a test carb or prototype for an advanced unit or maybe a dismal failure. I once bought an accessory oiler for a T and wondered why they found a warehouse full. After thinking about it and reading the instructions I believe it was a failure because the oil reservoir was mounted to the exhaust manifold. In use it must have cooked or even ignited the oil!
08-03-2021, 03:47 PM | #3 |
Re: Whatzit agian
That looks like a nice little tank should be good to use somewhere. As for the carb I may look inside sometime, maybe try it on something. Just odd it’s the only no name I ever saw.
08-04-2021, 03:42 PM | #4 |
Re: Whatzit agian
It is an "Air Friction" carb. Google "Air Friction carburetor" & scroll down to antique carburetor/ OEM. Second page shows a 20's ad.
08-04-2021, 06:25 PM | #5 |
Re: Whatzit agian
Wow, that is cutting edge. Thank you for the info, maybe I will try it on my T for fun & 40 mg
08-28-2021, 08:27 PM | #6 |
Re: Whatzit agian
08-29-2021, 07:14 AM | #7 |
Re: Whatzit agian
OK thanks, will look around haven’t seen everything in the hash of parts could be the threaded tube is in there.
08-30-2021, 05:13 PM | #8 |
Re: Whatzit agian
Aluminium carb with windows in the bowl? |
