Old 06-05-2016, 07:50 AM   #1
1956 F100
1956 F100's Avatar
Default 1934 Tudor Windows
Would anyone have a picture of the back window channel attached to the glass. I am using a vintique window kit and it needs to be cut down to work. Would like to be sure I am cutting in the correct place to allow it to work. I want the window to slide back and down like the factory. Thank you Gary
1956 F100 is offline   Reply With Quote
Old 06-05-2016, 04:02 PM   #2
lbford25
Default Re: 1934 Tudor Windows
This is one of the back windows intact. On the other side..I have taken out the window and the frame channel setup attached to the handle. The window back channel is still in the panel space but can be seen from on top. The panel is difficult to take off. I'll take a pic of the frame channel or measurements if that will help.
lbford25 is offline   Reply With Quote
Old 06-06-2016, 09:07 AM   #3
lbford25
file size too big. here are the pics at a smaller size.
Old 06-06-2016, 09:54 PM   #4
johnboy34
Angry Re: 1934 Tudor Windows
Have you seen this? I went off this to fix mine. The stop screw in the channel is off and the roll back pin on the bottom bracket is off. The sliders don't fit worth a darn either. I have pictures showing operation but cant find them, I'll keep looking.
johnboy34 is offline   Reply With Quote
Old 06-06-2016, 10:22 PM   #5
johnboy34
Some other reading...
http://www.jalopyjournal.com/forum/t.../#post-2740182
Old 06-06-2016, 10:41 PM   #6
johnboy34
Even more reading... The bottom one explains how they work so you can figure what you need to do to them...
http://www.fordbarn.com/forum/showth...indow+channels
http://www.tagchips.com/CARS/34FORD/...NDOW_REGULATOR
Old 07-31-2016, 12:15 PM   #7
1956 F100
1956 F100's Avatar
Thanks guys
