Old 07-30-2022, 08:31 PM   #1
dad's deuce roadster
dad's deuce roadster's Avatar
Default front motor mount cushions
I've been looking to replace the rubber cushions the motor mounts sit on in our 32 roadster. Nothing seems cut and dry to be certain what's offered actually matches what we we have which are likely original but even if not, are no later than 1950's parts. The set here
[URL="https://bobdrake.com/collections/engine-mount/products/1932-36-motor-mount"]
looked OK, but when I called the company I got only a recording. Guidance on a good source would be appreciated.
thanks
dad's deuce roadster is offline   Reply With Quote
Old 07-30-2022, 09:12 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: front motor mount cushions
Speedway motors also has the universal '32-'36 motor mounts.
https://www.speedwaymotors.com/Unive...q=motor+mounts
Old 07-30-2022, 09:25 PM   #3
DavidG
DavidG's Avatar
Be persistent; Drake's aren't just okay, they are the best.
Old 07-31-2022, 03:52 PM   #4
41ford1
41ford1's Avatar
The Bob Drakes mounts are the best. The Speedway mounts do not have the cupped base washer. There is nothing to prevent the cushion from expanding and flattening under load.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 07-31-2022, 03:55 PM   #5
Krylon32
Drakes
Krylon32 is offline   Reply With Quote
Old 08-01-2022, 08:17 AM   #6
36coupe
36coupe's Avatar
Rock auto sell just the rubbers.
36coupe is offline   Reply With Quote
Old 08-01-2022, 08:28 AM   #7
DavidG
DavidG's Avatar
41ford1,
The cups aren't used on a '32 unless the front cross member is a very early one without the stamped-in depressions that serve the same function as the cups. The cups do not reappear until the '35 model year.
