06-22-2015, 06:35 PM | #1 |
40 pickup front clip on a 46 ford pickup
I have most of the parts for a 40 ford pickup front clip and I would like to put it on my 46 ford pickup. Has anyone done this? What problems am I going to have? Thanks, 45yellowford
06-22-2015, 08:36 PM | #2 |
Re: 40 pickup front clip on a 46 ford pickup
I'm sure it can be done, but 35-41 truck (to 40 with cars) frames are quite a bit different than the 42-through F1 series of pickup frames.
06-22-2015, 09:09 PM | #3 |
Rcab sits too high for one thing. Most that have been done look horrible. The only one I have seen on the stock 42-47 frame that looked OK the cab had been channeled about 6" and had a mustang II front end. But then there is the running board issue to custom fit
If you want it to look right change the cab over to the 35-40 frame like mentioned above but there are a few little things that still need adjusted to work |
06-23-2015, 11:00 AM | #4 |
Why not locate a 46-47 front clip? I love the jail bar pickups and they just don't get the attention they deserve.
Respecting and Resurrecting Ford Model A's. |
06-23-2015, 11:24 AM | #5 |
I've seen a couple of attempts at this and they were fugly!
06-23-2015, 11:28 AM | #6 |
06-23-2015, 01:14 PM | #7 |
^^^^What Karl said!!
36 Fords Rule! Visit at www.36fords.com. |
06-23-2015, 03:19 PM | #8 |
Thanks for the info. You convinced me not to try the change.
45yellowford |
06-23-2015, 04:14 PM | #9 |
I now have a 41 Ford Pickup front clip for sale. I will take it to the next swap meet unless someone on Ford barn is interested. Freight could be an issue since I live in Idaho.
45yellowford |
06-23-2015, 04:17 PM | #10 |
That's a good looking truck. Doesn't need any changing!
