03-18-2020, 08:46 AM | #1 |
Lower radiator hose heater hose fitting
I ordered new radiator hoses for my 1941. The passenger side lower hose has a fitting to attach the heater hose. The new hose did not come with the fitting. Before I try to attach the fitting to the new hose i would like your advice. It appears that the fitting comes apart and can be inserted in the hose after a hole is cut in it.
03-18-2020, 08:56 AM | #2 | |
Re: Lower radiator hose heater hose fitting
03-18-2020, 09:05 AM | #3 |
Thanks, rockfla. That is how I figured it should work. Just needed a second opinion as I can (and do) screw things up.
Joe |
03-18-2020, 09:11 AM | #4 |
I did it the same way as rockfla did it for my 46 Deluxe, except I used a 3/4 x 1 1/2” piece of hardwood and a hole punch the same size as the pipe barb. It was 5/8” if I recall correctly.
03-18-2020, 10:07 AM | #5 |
ALSO, don't get in a hurry and not "think" and put the RTV on the outside of the outer washer like i did too. It goes "underside" knock on forehead!!!!
03-18-2020, 10:32 AM | #6 |
03-18-2020, 06:08 PM | #7 |
Thanks, everyone. I got it done and guess what? It doesn't leak!!
The Ford Barn helps me again !!! |
