Old 04-29-2021, 01:48 PM   #1
Doug 845
Default 1927 Model T Brakes
Trying to learn about the braking system on a T. Did the '26 & '27 have functioning rear brakes? Or were the only brakes actually used while driving just the bands in the tranny?
Doug 845 is offline   Reply With Quote
Old 04-29-2021, 02:54 PM   #2
Ray in La Mesa
Default Re: 1927 Model T Brakes
The rear brakes are actually a parking brake as they are cast iron band w/ no shoes. Only driving brakes are the band in the transmission.
Ray in La Mesa is offline   Reply With Quote
Old 04-29-2021, 10:24 PM   #3
stevests
stevests's Avatar
The "Improved" Ford ('26 - '27) actually had a lined rear brake band - earlier were cast iron.
stevests is offline   Reply With Quote
Old 04-30-2021, 09:48 PM   #4
J Franklin
J Franklin's Avatar
Lined parking/emergency brake bands. If you want rear brakes buy an accessory Rocky Mountain type set-up.
Old 05-01-2021, 07:10 AM   #5
jimTN
The inside brake shoe or "band" as I think you are calling it in 26/7 was lined. There is a external accessory brake outfit called Rocky Mountain brakes that has a external contracting band on the outside of the brake drum.
Old 05-04-2021, 06:50 PM   #6
Alex Mcknz
Thanks for sharing this trivia.
I am learning a lot of things about classic cars on this forum.
Alex Mcknz is offline   Reply With Quote
Old 05-20-2021, 11:04 AM   #7
FiretrucK
The 26-27 T park brakes are much larger than the earlier park brake. There is a outfit ( Model T Ranch ) that makes a equalizer to connect the park brake to the brake paddle so they can be used as a service brake. There are mixed revews on how well they work.
FiretrucK is offline   Reply With Quote
Old 05-20-2021, 01:51 PM   #8
redmodelt
redmodelt's Avatar
Biggest draw back using the 26/27 as service brakes, they just float inside the drum, not anchored down. Yes people do use them as parking/service brakes. As bad as Rocky Mtn are reported to be, that at least do have one anchor point.
