01-30-2016, 07:54 PM | #1 |
Dropped axle
My 47 Ford Deluxe needs a front end overhaul and I'd like to keep it lowered somewhat. I noticed the previous owner heated the springs to lower it. The entire brake system has already been rebuilt and I'll probably just keep the drum brakes for now. I suppose what I need is a dropped axle, new spring, and shocks. I know Sid's is in the OKC area to provide some help. Anything else effected by the dropped axle ? I found some of my old Rod & Custom mags today. Too bad the dropped axle prices still aren't the same. This one is from July '57.
01-30-2016, 07:57 PM | #2 |
Re: Dropped axle
Sid's in Guthrie is THE source.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
01-30-2016, 08:05 PM | #3 |
Re: Dropped axle
The spindle arms will need to be heated and bent to maintain your turning radius. Rather than heating and bending them you should cut them off and bolt on new arms. Use Chassis Engineering arms or those sold by Speedway or other hot rod vendors
01-30-2016, 09:20 PM | #4 |
Re: Dropped axle
Send Sid your spindles. He will bend them. Well worth the money.
01-30-2016, 09:45 PM | #5 |
Re: Dropped axle
Don't even think about an aftermarket axle, go with Sid's, original Ford parts all the way.
01-31-2016, 01:31 PM | #6 |
Re: Dropped axle
01-31-2016, 01:36 PM | #7 |
Re: Dropped axle
You can drop and stretch an axle to what you need it to be.
If it gets thin stretching, fill it for added strenght. |
01-31-2016, 01:56 PM | #8 |
Re: Dropped axle
Normally, when the two ends are dropped without stretching, the axle width (king pin center line) will decrease slightly. Most axle droppers are capable of stretching the ends while dropping to maintain original width. Dropped ORIGINAL Ford axles is the ONLY way to go, metalurgically, and to retain original perch dimensions. DD
01-31-2016, 02:13 PM | #9 |
Re: Dropped axle
If you are going to be replacing the front spring why not replace it with one with reversed eyes to lower the front end? The moly-nylon button insert type ride very well and you can retain the stock axle, wishbone and crossmember. Pretty significant lowering too.
01-31-2016, 02:20 PM | #10 |
Re: Dropped axle
Anson Axles, Grey Haynes. The best I've found.
01-31-2016, 02:36 PM | #11 |
Re: Dropped axle
Call Sid, he will tell you what they can do. It is my understanding thay will custom do the drop however you want (within reason and safety).
04-09-2016, 04:40 PM | #12 |
Re: Dropped axle
For those with lowered front ends, what shocks are you using? I assume they need to be shorter.
04-09-2016, 05:21 PM | #13 | |
Re: Dropped axle
Same would apply if the shock is attached to the spring perch bolt, the relationship between the perch bolt and the frame should not be changed by installing a dropped axle. Last edited by JSeery; 04-09-2016 at 05:27 PM. |
04-09-2016, 05:56 PM | #14 |
Re: Dropped axle
The least expensive way to get a 1 1/2" drop is, as one Fordbarner already suggested, with reversed spring eyes. Very simple process of re-arching the spring cold in the press. To much dropped axle, spindle steering arm hits, reducing turning radius as already pointed out. if you can find an original "Moredrop" axle, they work the best, and look good doing it.
04-09-2016, 06:42 PM | #15 |
Re: Dropped axle
Like everyone has said, reverse eye spring slight drop with stock axle, drop axle with stock spring more of a drop and reversed eye spring WITH a drop axle is on the ground . I've used Anson and Okie Joes (Sids doesn't do 28-36, he sends them to Joe's)...it depends who your close to.
If you do go the drop axle route make sure you send your axle AND spindles to Sid so he can drop your spindles to your axle. Also original Ford axles and spindles are the ONLY way to go. |
04-09-2016, 08:36 PM | #16 |
Re: Dropped axle
You may also want to consider running 15" Mercury rims on the front.
04-10-2016, 08:53 AM | #17 |
Re: Dropped axle
When I purchased my last drop axle I went with Magnum. At the time they were the only aftermarket ones that didn't require splitting my wishbones. I plan on contacting Sid's for my current build but it may be a while. Please keep us informed with your decision and outcome.
Thank God this is only a hobby! |
04-10-2016, 11:44 AM | #18 |
Re: Dropped axle
I'm with the reversed spring eye crowd. That's what I did on my 39.
04-10-2016, 11:57 AM | #19 |
Re: Dropped axle
It depends on the amount of drop you are after! On my 33 I have reversed spring eyes, removed spring leaves, dropped axle and raised the spring mount. Dropped axle was 2 inches, the spring an inch and the mount an inch and the relaxed spring, so 5 inches. Then the rims and tires are the smallest diameter that allows me to maintain the scrub clearance. It the old Alice in Wonderland deal, which way you go depends on where you want to end up!
04-10-2016, 12:01 PM | #20 |
Re: Dropped axle
My 37 has a dropped axle, reversed springs, and 15" wheels with small diameter tires.
Tommy |
