Old 11-19-2019, 06:40 AM   #1
3twinridges
3twinridges's Avatar
Default Repainting an engine
When dad and I built our freshly machined 8BA two years ago I used VHT rattle can primer and engine paint. When we first fired it up we had a gas leak and it lifted some of the paint on the intake and top of the block. I need to touch that up and recoat it. Since then I have been introduced to Bill Hirsch engine enamel and really like that paint and would like to recoat the entire engine in it. My thoughts were to rough up the block with 320 paper and reshoot it. Has anyone shot over VHT rattle can paint with Bill hirsch and had good results?
JB
3twinridges is offline   Reply With Quote
Old 11-19-2019, 06:45 AM   #2
Ian1932
Ian1932's Avatar
Default Re: Repainting an engine
JB
I would also think red/maroon scotch brite would help you scuff everywhere and form to some of the shapes. I would want to make sure that it is completely scuffed everywhere. Before you sand, clean with prepsol and the again after you sand right before paint. Oil would be your enemy i would think....
Ian1932 is offline   Reply With Quote
Old 11-19-2019, 09:07 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
I would clean the loose paint off first.
Then I would get a good quality foam brush and brush on the paint. You will get better coverage on the cast iron and the Bill Hirsch paint flows nicely so you will not see brush marks and it will look like you sprayed the paint on with a gun. No over spray mess and clean up is easy.
I've done this on many blocks and the latest 1940 engine I built is going in a Dearborn class car. It's beautiful.
Seth Swoboda is online now   Reply With Quote
Old 11-19-2019, 10:06 AM   #4
JSeery
JSeery's Avatar
For me brushing on the engine paint works best, it really flows out nice!
Old 11-19-2019, 10:12 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
Looks like a bit of porting on that block . . . good for you! I tend to like things like this. LOL
Bored&Stroked is online now   Reply With Quote
Old 11-19-2019, 10:23 AM   #6
JSeery
JSeery's Avatar
Yep, early stages of it.
Old 11-19-2019, 11:41 AM   #7
3twinridges
Thanks guys
Old 11-19-2019, 12:00 PM   #8
rotorwrench
rotorwrench's Avatar
Try a spot and see if the paint lifts. You never know with some of the rattle can stuff. I've seen some bubble right up as soon as any solvent hits it. Fuel is also a volatile form of naphtha and it just depends on how long the paint was exposed to it as to how long it took for it to bubble up.
Old 11-19-2019, 01:02 PM   #9
Seth Swoboda
Looks good, great coverage.
Old 11-19-2019, 03:45 PM   #10
mfirth
Only painted 2 flattys & used Hirsch on both.One brushed & one sprayed,VERY satisfied.
mfirth is offline   Reply With Quote
Old 11-20-2019, 07:24 AM   #11
chap52
chap52's Avatar
Hint: if there are bolts or ? you want to avoid painting instead of using tape try little pieces of aluminum foil...easier to manage... Chap
Old 11-20-2019, 08:00 AM   #12
3twinridges
Good stuff guys, thanks.
JB
Old 11-20-2019, 08:23 PM   #13
Desoto291Hemi
Hey JSeery,
I like the paint you did.
What kind of brush did you use?
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 11-20-2019, 08:25 PM   #14
JSeery
JSeery's Avatar
Originally Posted by Desoto291Hemi View Post
Hey JSeery,
Tommy
Just a cheap throw-away brush. It's the paint, it really flows well.
Old 11-20-2019, 08:52 PM   #15
philipswanson
Backorder Bob's (Drake) paint works good too when brushed.
philipswanson is offline   Reply With Quote
Old 11-20-2019, 09:18 PM   #16
Desoto291Hemi
My Mercury calls for Green or Tangerine.
I would like to try the Tangerine,,,,,I assume it is a Ford paint code?
Tommy
Old 11-20-2019, 10:05 PM   #17
Tinker
Tinker's Avatar
Eventually any paint will be overcome to the heat cycles. Clean it best you can from paint and oil and apply. Probably last 5-6 yrs or more, or more if you don't drive it.
Old 11-21-2019, 02:43 PM   #18
4t7heaven
As an old sign painter, I would suggest adding a little Penetrol to the paint. Really helps with the "flow" of the paint and it does not "thin" the paint as adding thinner would do.
4t7heaven is offline   Reply With Quote
Old 11-21-2019, 05:05 PM   #19
JSeery
JSeery's Avatar
The Bill Hirsch paint does not require any thinners, no idea on other paints.
Old 11-23-2019, 10:10 AM   #20
3twinridges
We are going to pull the engine and repaint it. Scuff it up and such and get it clean for a repaint. Would you use a rattle can primer before the Hirsch paint or shoot it with DP50 ppg epoxy to ensure good bite?
JB
