Old 09-19-2011, 04:32 PM   #1
hehillsy
hehillsy's Avatar
Default KR Wilson Tools
Anyone looking for hard to find KR Wilson tools may be in luck.Check out my website at krwilsontools.com and click on (For Sale or Trade) button. Hope you find what you are looking for and enjoy the information I am sharing. Thanks Tim
hehillsy is offline   Reply With Quote
Old 09-19-2011, 04:48 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: KR Wilson Tools
I have a question, ....I have enclosed a couple of pics showing your KR Wilson rear axle stand however I'm not sure exactly the benefit of these. I looked closely at one of these over the weekend and did not see a labor savings value in this tool. Can you explain how this would work as it would seem extremely difficult to remove/install the axle housings and to install the axles & carrier while setting up the clearances. What am I missing??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-19-2011, 06:49 PM   #3
eystein
eystein's Avatar
Brent,
I see no use when assembling the axle.
I made a simple stand from scrapwood in an hours time which would bolt to the four backing plate holes with the left axle end pointing downwards. This was handy, building the axle from the left side up, and when adjusting gaskets for carrier preload, and during final assembly. For safety I also loosely tied the axle to my workbench with a rope.
The use I could see for the KRW stand would be during backing plate and brake assembly. However, unless you do that every day I would never bother getting anything as sophisticated as that. Something much simpler did just fine for me.
eystein is offline   Reply With Quote
Old 09-19-2011, 06:56 PM   #4
Bruce Lancaster
Not all KRW stuff was for Ford...maybe it was a generic piece. It would make sense for most other axles, and I have seen pictures of stands much like that in a variety of old car manuals.
Old 09-19-2011, 06:57 PM   #5
HoarseWhisperer
HoarseWhisperer's Avatar
Would be interested in knowing the collector value of the KRW Rear Spring Assembly Press?
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 09-19-2011, 07:18 PM   #6
hehillsy
hehillsy's Avatar
I have seen the likes of your KR Wilson spring press sell on Ebay from $75.00 up to $200.00
Old 09-19-2011, 08:22 PM   #7
nostalgicford
nostalgicford's Avatar
the axle stand is not only handy for the rear end but is gr88 for the front end...you can knock out spring perches...kingpins...and replace...also install backing plates and brakes and even the front spring....I have a KRW axle stand and a Dixie made in Deaborn, Mi...it is actually better than the KRW
nostalgicford is offline   Reply With Quote
Old 09-19-2011, 08:26 PM   #8
Kohnke Rebabbitting
Bruce, the Wilson stand first came out for the Model A Ford, and used at least through the 40's, cost was 26.00. in the Model A years. Brent you are right about the stand, as they had fixed housing clamps, wasn't as usefull as it could have been. The Weaver is the best one, as you can clamp a housing at any angle, on either side. I had 5 Wilsons I bought for resale, and have used my Weaver, for over 35 years now.
Kohnke Rebabbitting is offline   Reply With Quote
Old 12-17-2012, 02:34 PM   #9
BigDTexasKid
I have a K.R. Engine Stand & Base, I use a Manzel Rear End Holder. This Works great for
Early V/8, Ford 8-3/4, 9, etc. I Attachment will Rotate 360. I never seen one for Sale on eBay or Ford Barn. But, I haven't seen KRW Spring Spreader For Rear End or the Front Cast
Steel Accessory. That is used to work on Front Axle.
BigDTexasKid is offline   Reply With Quote
Old 12-17-2012, 03:14 PM   #10
Joop
Joop's Avatar
HoarseWhisperer check this out.
Click here: K R Wilson Model A Ford Spring Spreader Assembly Press A 321 KRW KR A321 28 31 | eBay
Joop is offline   Reply With Quote
