Old 11-07-2023, 08:10 AM   #1
30ccpickup
30ccpickup's Avatar
Default Key Taper Direction
In my last question, the direction of the key tapper became a topic. I went through my collection of Ford books and found this in the 1925 Ford Service Manual.
"639 The hub key is then inserted into keyway on axle shaft as shown at "B' and is forced into keyway by tapping it with a small ham- mer. When installing hub key the tapered end of the key should point toward axle housing as shown at "B"."
Just an observation, when the hub is pushed on, the key would slide forward tightening to the top and bottom of axel and hub and when pulled off the key slides backwards releasing the contact area.
In my case, since the key was stuck in the axel it would not slide and loosen when attempting to pull the hub.
Original post:
https://www.fordbarn.com/forum/showthread.php?t=332754
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 11-07-2023, 11:45 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Key Tapper Direction
I almost asked what a "key tapper" was and now see what the question was. Yes the taper goes toward the banjo or inside and down toward the axle because of the end of the keyway.
Old 11-07-2023, 01:09 PM   #3
30ccpickup
30ccpickup's Avatar
My grandmother had the gift of spelling, somehow I missed out.
