Old 05-30-2021, 05:10 PM   #1
Ruth
Default Stipe Shocks
Has anyone ever had to add oil to Stipe Shocks and if so what oil did you use. I don't need to add oil to mine, just curious for future knowledge.
Ruth
Old 05-30-2021, 05:48 PM   #2
Jim in Wisconsin
Default Re: Stipe Shocks
They are filled with hydraulic oil at assembly.
Jim in Wisconsin is offline   Reply With Quote
Old 05-30-2021, 08:00 PM   #3
Ruth
I realize that. But unlike other repro Houdaille type shocks, Stipes can be refilled if needed.
My question is: Has anyone ever had to add oil to Stipe Shocks and if so what oil did you use?
Ruth
Old 05-30-2021, 08:14 PM   #4
Benson
Benson's Avatar
The data sheet that came with my Stipe shocks says to use:
Full Synthetic Hydraulic oil 30 to 40 weight.
Only fill to within 1/16th inch of bottom of filler hole ...
Leave air to allow for expansion.
Reseal plug with SMALL amount of sealer.
End Quote
Benson is offline   Reply With Quote
Old 05-30-2021, 10:55 PM   #5
Ruth
End Quote
Thanks for the response Benson. My Stipe Shocks were on the car when I bought it and I didn't receive the data sheet.
Since I posted my question I found on The Ford Garage to use "modern premium ISO 150 synthetic hydraulic oil".
But my original questions were still not answered.
Ruth
Old 05-31-2021, 04:05 AM   #6
Benson
Benson's Avatar
Ruth,
THANKS FOR referring me To Vince FALTER'S site for conversion to ISO.
About leaks I have two sets of Stipe shocks for 3 -4 years and no leaks.
Here is a table that converts ISO 150 to 40 weight which agrees with VINCE'S INFO which is always based on research.
Looks like ISO 100 equals 30 weight
and ISO 150 is 40 weight
Note when I click on this link the info appears in Downloads file (drop down window in lower left below this page.)
You must click on link to see info.
That is the way my computer is setup anyway.
File Type: pdf ISO Grade Oils - Viscosities and Densities CHART.pdf (132.1 KB, 17 views)
Old 05-31-2021, 10:07 AM   #7
700rpm
700rpm's Avatar
Relevant to this, what do you use to fill the shock with?
Ray Horton, Portland, OR
