06-04-2018, 10:41 PM | #1 |
Tie rod too long
I installed a new tie rod in my 1929 roadster but could not achieve the proper toe-in measurement because I ran out of threads on the ends. I later measured the bent original (43") but the new one is 44" long. Question: are there different tie rod lengths for each model year?
06-04-2018, 11:20 PM | #2 |
Re: Tie rod too long
No, one size should fit all, although the spindle arms did change their distance a little.
06-04-2018, 11:27 PM | #3 |
A longer tie rod should allow more toe in.
06-04-2018, 11:37 PM | #4 |
yeah, OP said proper toe in, not that he couldn't get any toe in. If he ran out of threads he was trying to reduce toe in due to the tie rod being too long. My tie rod was bent up. It wasn't a big job to straighten it. I would say fix the original if at all possible.
-edit- re-reading this post I sound sort of short-tempered, didn't mean it that way
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool." Last edited by eagle; 06-05-2018 at 08:15 PM. |
06-05-2018, 12:21 AM | #5 |
I see, he ran out of threads on the inside.
06-05-2018, 05:18 AM | #6 | |
So it sounds like your '29 roadster may be fitted with '28 spindle arms by a previous owner. I hope this helps. Feel free to PM or email me with follow up.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
06-05-2018, 09:59 AM | #7 | |
Off the top of my head..I think your backwards, best guess. The arms that are closer too the backing plates take a longer tie rod.. Dudley |
06-05-2018, 11:41 AM | #8 |
Dudley,
I put on one of Arts' "T" shirts, BACKWARDS & no one EVEN noticed it--LOL Willy Bill
06-06-2018, 09:34 PM | #9 |
Could someone tell me the size and thread count of these tie rod threads? Glynn.
06-07-2018, 11:29 AM | #10 |
The thread size on the ends of the tie rod are 11/16-24 and about 2" long.
One end is right hand threads and the other end is left hand threads. The right hand threads are threaded into the left hand tie rod end fitting. |
06-07-2018, 05:35 PM | #11 |
Do you have a dropped axle?
06-08-2018, 01:17 AM | #12 |
No I do not have a dropped axle. The roadster was restored about 20 years ago and I do not have the history on it. I am beginning to believe that it is a 1928 with a 1929 motor and transmission.
06-08-2018, 08:32 AM | #13 |
LEM,
Would you consider having a welding shop cut a small amount from it & re-welding it? The rod is hollow & a piece of round steel could be put in it, for safety. Bill W.
06-08-2018, 02:32 PM | #14 |
Bill:
The rod that is too long is a new solid one. I could cut an inch off the right hand threaded end and then chase the threads down the rod one inch further. But I thank I will have the original hollow one straightened (I like original). |
06-08-2018, 03:02 PM | #15 |
Thanks LEM for the info. Glynn
06-08-2018, 06:50 PM | #16 |
Lay the original hollow rod in the V of a thick piece of angle iron, then use a block of wood and 3 pound hammer to straighten it.
06-08-2018, 07:08 PM | #17 | |
Minervas' hollow one was bent by "someones'" damper, that had some HUGE shock on it. Removed & trashed the damper & pried the rod straight, on the car, with a 2 Ft 2X4. Found that the TOE-IN was PERFECT! Bill Easy
06-16-2018, 05:58 AM | #18 |
06-16-2018, 01:58 PM | #19 |
Brattons is 44.0 long @ $19.00
Mike's is 44.0 long @ $14.95 Snyder's is 43.4 long @ $14.95 Mac's is 43.5 long @ 30.99 Smith & Jones is 44.0 long @ $17.00 ( this is the one I bought and is too long) Bottom line- measure before you order! |
