06-13-2021, 04:01 AM | #1 |
Advice Required2 - M47 Pickup 12v Conversion
Hello all,
Is someone able to point me into the right direction for instructions on converting my 1948 Merc M47 pickup from 6volt to 12volt and where I can obtain a quality 12v wiring harness from? Thanks to you all in advance. |
06-13-2021, 05:46 AM | #2 | |
Re: Advice Required2 - M47 Pickup 12v Conversion
For the sake of originality you can obtain an original harness from various vendors. This is just one source----- https://www.riwire.com/ |
06-13-2021, 08:23 AM | #3 |
I'm not going to get into the 6 versus 12 debate but I used a Rebel wire 9+3 kit when I rewired my '39 p/u and changed over to 12 volt. Excellent product and from all accounts they have great tech support but I didn't need it. USA made as well.
http://rebelwire.com/rebel-wire-prod...at=Wire%20Kits
Making the simple complicated for over 30 years. |
06-13-2021, 12:52 PM | #4 |
I converted my M 47 to 12 volt. Once again, very easy and not too expensive. I used Speedway's 12 circuit kit, instructions are easy to follow. I've used that kit on 5 trucks so far, it takes about a day to do the job. Converting or not converting the gauges is your hardest decision.
06-13-2021, 02:48 PM | #5 |
You might also do a search here on the FordBarn... it's been covered many times.
06-14-2021, 02:47 AM | #6 |
