10-02-2012, 09:21 PM | #1 |
identifying transmission gears
I just picked up a T86 overdrive transmission for my 57 wagon. It is apparently out of a 61 ford car and appears to be just what I need. The trans and overdrive unit are in great shape, all except the imput shaft which looks like it was exposed to the weather. The shaft that goes into the pilot bearing is badly deteriorated. I can't think of a way to fix this so it looks like I need another imput shaft. My question is, is there a parts book available that I can check out how many different imput shafts were used in the T86 and their application? is there a good source of manual trans parts. thanks
10-03-2012, 01:38 AM | #2 |
Re: identifying transmission gears
You might want to check with www.usapartssupply.com but give them a call to ask them,they do stock some gears and repair parts.
10-03-2012, 01:53 AM | #3 |
You would the the 49/59 FORD MPC (Master Parts Catalog). Parts lists would be detailed there.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
10-03-2012, 08:12 PM | #4 |
Thanks guys. I appreciate your responses. Has anyone out there purchased one of these master parts catalogs that are available on CD ROM?
10-03-2012, 08:15 PM | #5 |
sorry I hit the return too quickly. I ment to ask if anyone has purchased one and was the quality acceptable?
10-03-2012, 09:25 PM | #6 |
10-04-2012, 01:21 AM | #7 | |
http://www.faxonautoliterature.com/Default.aspx
10-04-2012, 08:41 PM | #8 |
Thanks Mac. It has 18 teeth. I'll bring it with me to Owensville this weekend so that you can take a look.
KULTULZ "If it is marked FORD LICENSED, it will be a quality product." I would like to think so, just looking for comfirmation. I'm going to buy one. I will let you know how it turns out. |
Thread Tools | |
Display Modes | |
