Old 03-28-2021, 02:06 PM   #1
Dbug725
Default 8ba question
I'm working on an engine that was sold to me as a rebuilt 1953 8ba Ford. However as some of you might have read, I'm having a starter issue and it now appears that I do have a mismatch between the starter mounting plate and the bellhousing. The weird thing is that my bellhousing is steel (not cast) and everything I've read indicates that this is a Mercury bellhousing... or did Ford have a steel one in 1953? According to pictures that I've found in old files, I do have a starter mounting plate made by Ford. Is it possible that the Ford starter mounting is making an incorrect angle for the gear mesh with this Mercury? bellhousing. Maybe I'm clutching at straws....for three weeks I've been chasing this starter issue. Maybe this engine is really a Mercury.....I can't find any engine numbers at all..........for my first flathead project this is a real mystery. Any and all information would be greatly appreciated
Dbug725 is offline   Reply With Quote
Old 03-28-2021, 02:08 PM   #2
51504bat
51504bat's Avatar
Default Re: 8ba question
post some photos
Old 03-28-2021, 02:10 PM   #3
JSeery
JSeery's Avatar
There are not any differences in the blocks themselves between a Ford and Mercury. Some photos of your starter plate and bellhousing would help a lot. I can post the photos for you if you email them to me. [email protected]
Old 03-28-2021, 02:21 PM   #4
19Fordy
19Fordy's Avatar
Be sure to read ALL of this post:
https://www.fordbarn.com/forum/showt...y+bell+housing
Do you have the little "L" bracket that bolts to the back of the starter and the oil pan in place? This helps support the starter for correct alignment. Looks like this:
https://www.ebay.com/sch/i.html?_fro...acket&_sacat=0
Old 03-28-2021, 02:25 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
Dbug....As JSeery said, there is ABSOLUTELY no difference between Ford & Merc blocks...'49-'53....PERIOD!
If you'll look through the PDF file listed below, it is a site that fellow 'Barners "V8Bob" and "Moe's Garage" compiled years ago actually showing every bellhousing/starter plate combination that exists for 8BA-type engines. For info on each picture, place your cursor on the QUESTION MARKS at each picture. It don't get NO better than this valuable info! Click the link below! DD
https://web.archive.org/web/20160318...ellhousing.pdf
Click Links Below __
T5 W/TORQUE TUBE
Old 03-28-2021, 03:36 PM   #6
Dbug725
Thanks for the offer to post pics for me.....as you can see I'm challenged when it comes to computers. I'm going to check out the link below to see if this link helps clear up as to what I actually have. I might have to send you pics later if I can't figure things out. I really appreciate all you guys do to help newbees like me. I'm more than willing to learn but without someone else having the knowledge I'm lost.
Old 03-28-2021, 09:07 PM   #7
JSeery
JSeery's Avatar
Flatheads are a whole different animal than later engines. Not that difficult, just very different if you've never been around them. Hot Rodders grew up working on them in their backyards! Lots of knowledge here on the Barn to help with just about any question you might come up with.
Old 03-28-2021, 10:53 PM   #8
flatjack9
flatjack9's Avatar
Ford did have a steel bellhousing in 1953. My mistake, no such thing.
Old 03-29-2021, 09:45 AM   #9
pistonbroke
Just went through this myself. If you have the steel merc bell that bolts up to the early transmissions, the starter plate off the ford will bolt on but your starter will be at a odd angle. Set the starter plate on a level surface and set a level on the starter opening it should be level. If not you have the wrong one.
pistonbroke is offline   Reply With Quote
Old 03-29-2021, 01:53 PM   #10
deuce5wndw
deuce5wndw's Avatar
The 49-50 steel bellhousing requires a starter plate that has an angle to it. If you have the flat steel plate it would put your starter at an angle.
deuce5wndw is offline   Reply With Quote
Old 03-29-2021, 02:04 PM   #11
deuce5wndw
deuce5wndw's Avatar
some photos
Old 03-29-2021, 03:16 PM   #12
Dbug725
I want to thank all you guys for the postings and help concerning my 8ba starter. The pdf files containing the bellhousing starter plate info was so helpful. Turns out that my two piece bellhousing was from a Mercury so that it mated with my 1938 transmission in my pickup. The starter plate did have the angled mounting flange but turned out that Merc did not have the angled bellhousing to mate with it. When I looked on the internet, I found a man listing flathead parts for sale.........turns out he was an old dirt track racer who collected flatheads for his race cars As luck would have it, he did have a Mercury two piece flathead bell housing with the standard starter mount plate bolted to it. He made me pay for the bell housing as well as the plate, but the great news was he lived less than ten miles from my home. Long story short, she cranks like a new one! As a bonus we got to talk about the old dirt track racing of the 50's and 60's that I loved so much. Everyone connected to keeping this forum alive should receive tons of thanks to help old guys like me work on the flatheads still alive today.
Old 03-29-2021, 06:35 PM   #13
V8 Bob
V8 Bob's Avatar
Originally Posted by deuce5wndw View Post
some photos
Curious about your pictured bell. Can you post more complete pictures as I've never seen one like that before.
V8 Bob is offline   Reply With Quote
Old 03-29-2021, 06:51 PM   #14
51504bat
51504bat's Avatar
Looks like the starter plate not the bell. Just a weird photo angle. IMO
Old 03-29-2021, 08:19 PM   #15
deuce5wndw
deuce5wndw's Avatar
Here you go. It's a 49-50 steel bellhousing.
Old 03-30-2021, 07:48 AM   #16
V8 Bob
V8 Bob's Avatar
These pictures are much clearer. 51504bat is probably correct about angles with the first pictures. JFYI, the stamped steel full bell was also used in '51 on Ford cars.
Old 03-30-2021, 08:50 AM   #17
deuce5wndw
deuce5wndw's Avatar
Sorry I was trying to show the angle in the first photos guess that was a flop. I thought the 52-53 bells were cast iron.
Old 03-30-2021, 10:14 AM   #18
51504bat
51504bat's Avatar
From what I understand the cast iron 1/2 bell on 8ba's was used in trucks and it will accept an 11 inch clutch. The stamped steel 1/2 bell was used in Merc's and will accept a 10 inch clutch but not an 11 inch.
Old 03-30-2021, 10:25 AM   #19
V8 Bob
V8 Bob's Avatar
Correct, the '52-'53 Ford and Mercury used the same cast iron full bell housing.
Old 03-30-2021, 10:57 AM   #20
marko39
I have a cast bell and starter plate from a pickup and an unknown stamped bell and starter plate. ( may be Merc.) they are the same as far as they are interchangeable with all dimensions the same.
marko39 is offline   Reply With Quote
