Old 09-22-2016, 08:29 PM   #1
leesmodela
Default carb & head
found a winfield intake with two carburators , & riley two port head on 1931 model a pickup . what would the value of this setup ?
leesmodela is offline   Reply With Quote
Old 09-22-2016, 08:37 PM   #2
Dick Steinkamp
Dick Steinkamp's Avatar
Default Re: carb & head
Which set up? The Winfield intake and carbs? The intake, carbs and the 2 port head? The intake, carbs, head and the pickup? In any case, pictures and description would be necessary before guesses can be made.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-23-2016, 12:30 AM   #3
Dodge
Depending on shape the intake and carbs are about $1600 to $1800 the Riley head
depends on if its a two port or 4 port. The two port is $4,000 to $4,500 and the 4 port,
haven't seen one for sale for a while, but more that the two port.
The pickup????
Just my opinion from what I've seen sell lately.
Maybe Jim Brierley can chime in here.
Dodge is offline   Reply With Quote
Old 09-23-2016, 03:07 AM   #4
waxhead
waxhead's Avatar
As stated above depends on lots of things. What model are the Winfield carburetors? The value varies greatly depending on the model, updraft vs downdraft, condition, if any parts are missing or if the carb is complete etc.
As for the Riley head, depends if it is original or a later reproduction.
waxhead is offline   Reply With Quote
Old 09-23-2016, 10:51 AM   #5
JimnOhio
Would that happen to be the same setup that was on the pick up that was part of the Ken Brownlee auction? From the pictures for that auction it looked like the head had been repaired (welded) a few times.
JimnOhio is offline   Reply With Quote
Old 09-23-2016, 11:45 AM   #6
leesmodela
yes this is from the browmlee auction . have removed the head to take a look at where it as been welded . have taking it down to noland's cylinder&head sevice ,in kansas city . say this head is very repairable . that people that weld on these heads with stick , or mig is not a good thing .
Old 09-24-2016, 10:41 AM   #7
Jim Brierley
As waxhead says, it depends on which carbs, and cyl. head condition. Carbs are stamped on the throttle-body and float chamber. The body determines the size of carb. Example S-1-B would be a B size, from memory, 1 1/4". Floats are stamped *-*-U or *-*-D. U being updraft and D being downdraft. The pair needs to be within 1 size of each other. Price varies with size, bigger are have more value, downdraft seem to attract more value too although performance is the same. I recently sold a matched pair of S-CC-U carbs for $1200 and had them advertised for several months. S, or SR are models of the most common Winfields. The head may be worth $3500, at the most. To sell quickly, price them right, as with anything. See the F.A.S.T. magazine for Winfield history, www.hotforhotfours.com. Thanks Dodge for the compliment.
Jim Brierley is offline   Reply With Quote
Thread Tools
Display Modes
