Old 12-16-2012, 10:07 PM   #1
krwilson5
Default painting manual transmissions
Did Ford paint their manual transmisson cases in the 50's? I don't remember ever seeing them painted, but it just doesn't seem right not to throw some paint on the overdrive I'm building before putting it in the car. Does anyone have any suggestions on what color Ford used in '57, or what you use on your transmissions?
krwilson5 is offline   Reply With Quote
Old 12-16-2012, 11:06 PM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: painting manual transmissions
The manual/od that was in my Ranchero had no paint on it at all. I know that don't mean a lot but there was no sign of paint, just rust and bare cast iron under the gunk covered area. I think I would clean it really well and paint it "cast iron" that comes in a rattle can.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 12-17-2012, 12:31 AM   #3
Y-Blockhead
Y-Blockhead's Avatar
I don't believe Ford painted their transmissions, manual or automagic. No ones going to see it anyway, unless your driving over them and at that point I don't think they care if it is painted or not.
I like the rattle can cast iron idea tho.
Old 12-17-2012, 09:46 AM   #4
Oldmics
Try that paint called "Cast Blast"
Looks really good.
Oldmics
Oldmics is offline   Reply With Quote
Old 12-17-2012, 03:26 PM   #5
Y-Blockhead
Oldmics, Have you tried Alumi Blast?
Old 12-17-2012, 03:29 PM   #6
PeteVS
PeteVS's Avatar
Alumiblast has a bright silver color. Castblast has a darker gray color just like cast iron.
Old 12-17-2012, 05:56 PM   #7
Oldmics
Why I"ve never even heard of Alumi Blast
I will certainly seek some out and give it a go.
Appreciate the tip
Oldmics
Old 12-17-2012, 11:44 PM   #8
zoegrant
zoegrant's Avatar
Seymour Paints Spray Paint Aerosol Satin Finish Stainless Steel 13 oz. Ea 16-054
Item # 390498457575....go to summitracing.com
zoegrant is offline   Reply With Quote
Old 12-18-2012, 01:05 AM   #9
Rowdy
POR-15 also makes a product called RPM that coats cast and it is still supposed to look natural. I have not tried it so I have no fisrt hand experience with it. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 12-21-2012, 07:58 PM   #10
krwilson5
Thanks for the good advice guys. I like the rattle can case iron approach. It'll give me some rust protection and the guy I run over won't even know it's painted. I'll go with the cast blast product.
Old 12-31-2012, 04:44 PM   #11
Hivolt5.0
Hivolt5.0's Avatar
When I rebuilt my 3 speed I stripped the case down, cleaned it real good and then used etching primer and finally a cast iron colored paint from Duplicolor. I thought it turned out pretty good.
Hivolt5.0 is offline   Reply With Quote
Old 01-08-2013, 07:47 PM   #12
krwilson5
I agree Hivolt5.0. That is exactly what I'm looking for. Did you paint first then assemble, or the other way around? Were you able to find all the small parts you wanted to replace? I'm looking for thrust washers synchro blocking rings, and complete small parts kit for my 57 T86.
Old 01-08-2013, 08:19 PM   #13
Mac VP
Mac VP's Avatar
The thrust washers, snap rings, and needle bearings are in the small parts kit. The synchro rings are another matter....getting more scarce it seems. We have the small parts kits. Would have to look to see if we have any of those rings. We also carry the gasket set and the oil seals if needed.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 01-09-2013, 09:08 AM   #14
Hivolt5.0
Hivolt5.0's Avatar
krwilson5, yes I dissassembled the whole transmission, cleaned the case real good inside and out and then painted it before I reassembled it. I was able to get the bearings, synchros and gaskets from Classic Auto Parts in Oklahoma City, OK. I travel there quite a bit and make it my ritual to stop by the store. You can look at my Ranchero photo album for a few pictures of what the transmission looked like before I started.
Also, check out Mac VP. I was going to recommend him to you. There's a wealth of knowledge in that man.
Old 01-17-2013, 08:27 PM   #15
krwilson5
Hi Mac. Sorry it has taken me a while to get back to you. I'm interested in the small parts kit , the gasket set, and the synchro blocker rings. I have the seals already. Any chance you have a used bearing retainer? the one I have is pretty rusty.
Old 01-17-2013, 09:02 PM   #16
Mac VP
Mac VP's Avatar
I have the small parts kit and the gasket set (which is strictly the paper gaskets). I'll check tomorrow to see if I can dig out some synchro rings. Did you also need the oil seals? Call our office after lunchtime and I can let you know if I found them......Mac VP
VANPELT SALES LLC
Cincinnati, Ohio
