Old 10-02-2012, 09:21 PM   #1
krwilson5
Default identifying transmission gears
I just picked up a T86 overdrive transmission for my 57 wagon. It is apparently out of a 61 ford car and appears to be just what I need. The trans and overdrive unit are in great shape, all except the imput shaft which looks like it was exposed to the weather. The shaft that goes into the pilot bearing is badly deteriorated. I can't think of a way to fix this so it looks like I need another imput shaft. My question is, is there a parts book available that I can check out how many different imput shafts were used in the T86 and their application? is there a good source of manual trans parts. thanks
krwilson5 is offline   Reply With Quote
Old 10-03-2012, 01:38 AM   #2
JeffB2
JeffB2's Avatar
Default Re: identifying transmission gears
You might want to check with www.usapartssupply.com but give them a call to ask them,they do stock some gears and repair parts.
JeffB2 is offline   Reply With Quote
Old 10-03-2012, 01:53 AM   #3
KULTULZ
KULTULZ's Avatar
Post Re: identifying transmission gears
You would the the 49/59 FORD MPC (Master Parts Catalog). Parts lists would be detailed there.
__________________________________
!!! AMBER ALERT !!!
FBI REPORTS A HI-JACKING OF A LARGE INTERSTATE SHIPMENT OF VIAGRA
BOLO FOR A GANG OF HARDENED CRIMINALS
KULTULZ is offline   Reply With Quote
Old 10-03-2012, 08:12 PM   #4
krwilson5
Thanks guys. I appreciate your responses. Has anyone out there purchased one of these master parts catalogs that are available on CD ROM?
Old 10-03-2012, 08:15 PM   #5
krwilson5
sorry I hit the return too quickly. I ment to ask if anyone has purchased one and was the quality acceptable?
Old 10-03-2012, 09:25 PM   #6
Mac VP
Mac VP's Avatar
If you don't know what make/model it came out of, you will have to do a tooth count on the main drive gear to have a chance to ID the part. Pop the cover, mark a tooth and do a count. We may have the gear.....
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 10-04-2012, 01:21 AM   #7
KULTULZ
KULTULZ's Avatar
If it is marked FORD LICENSED, it will be a quality product.
http://www.faxonautoliterature.com/Default.aspx
!!! AMBER ALERT !!!
Old 10-04-2012, 08:41 PM   #8
krwilson5
Thanks Mac. It has 18 teeth. I'll bring it with me to Owensville this weekend so that you can take a look.
KULTULZ
"If it is marked FORD LICENSED, it will be a quality product." I would like to think so, just looking for comfirmation. I'm going to buy one. I will let you know how it turns out.
