Old 04-24-2012, 09:35 PM   #1
krwilson5
Default resister required for a replacement coil
I bought an Accel 8140 Super Stock coil to replace what looked like the original coil on my '57. Good coil, I'm sure, but the package says nothing about an external resistor. Back in the day, coils came with a notice indicating that it did or didn't require one. I even went to the Accel homepage and still nothing. The original 57 uses one of course. Can anyone shed some light on this? Thanks.
krwilson5 is offline   Reply With Quote
Old 04-24-2012, 09:43 PM   #2
estout81
estout81's Avatar
Default Re: resister required for a replacement coil
If I was in dought I would use a resistor. Can't hurt coil with resistor but, without it could fry the coil.
estout81 is offline   Reply With Quote
Old 04-25-2012, 07:27 AM   #3
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
It's not the coil so much as the points if you're still running them. I would use the resistor. With points or a Pertronix system, a resistor should be used.
streetdreams is offline   Reply With Quote
Old 04-25-2012, 02:40 PM   #4
ford1
it needs a resistor, 1.35 ohm in the line to the coil, if the coil is getting around 9v to the coil after the resistor your fine
ford1 is offline   Reply With Quote
Old 04-25-2012, 03:17 PM   #5
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Your system (assuming its a point type distributor) requires 3-4 ohms of primary resistance to prevent burning the points up with excessive amps.
So a 1.5 ohm resistor and a 1.5 ohm coil would be 3.0 ohms, and when hot more toward 3.5-4 ohms..... 4 ohms would be 3 amps (where you need to be) and have a good life with the contacts.......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 04-29-2012, 09:08 PM   #6
krwilson5
Thanks for the info guys. It makes sense. i checked the coil's primary resistance in the online description and sure enough it was 1.2 ohms. I will pickup a new resistor to go with the coil. Thanks again.
