12-22-2014, 09:05 PM | #21 |
Re: Why Fiber Timing Gears
I'm with you Carl . I wouldn't want an engine with a fiber timing gear . As many fiber gears as I have had to replace over my life time, I sure as hell don't want to ever have to replace another. My experience with all of the fiber gears is that they don't last very long. The laminated gears are no exception. As often as we see stripped fiber gears on this forum should send a message to anyone with a question. Most of these stripped gears that we see have only been in service for a very short time. After seeing this so often here , anybody that insists on a fiber gear needs to get some real world experience replacing timing gears !!!
12-23-2014, 01:01 AM | #22 |
I was fortunate in that I had the engine out for other problems when I noticed missing/broken teeth in my less than 3K mile fiber timing gear. My friend wasn't so fortunate. His fiber timing gear let go while we were on tour, 200 miles from home. Again, less than 5K miles.
12-23-2014, 02:33 AM | #23 |
Carl and Purdy we keep sayin' but few are listening.....
'31 180A |
12-23-2014, 06:03 AM | #24 |
All my rebuilds are supplied with new crank gears and aluminum cam gears. I like others here have replaced cam gears that sheared for no reason and left me on the side of the road. Takes a lot of the fun out of the A.
http://www.model-a-ford-4bangers.com/ |
12-23-2014, 09:10 AM | #25 |
Many of you who are knowledgeable and have vast experience strongly advise using the metal timing gears. Dan's gears, especially a matched set has been well documented on this site as being some of the best. The problem that troubles many of us is that changing the crank gear is not a simple everyday event for the average Model A driver owner. Dan is not very encouraging when discussing only using his bronze gear with an existing, even new, crank gear. Pulling an engine is easier for some than others, and I guess until more people assure some of us that it won't be a terrible mistake to just install a quality metal timing gear, some will out of fear or confusion, keep on using the best fiber available.
12-23-2014, 09:54 AM | #26 |
When I talked with Dan he was equivocal about changing the crank gear if it was in good shape I too am thinking that changing the gear on the roadside on a tour would not be that much fun
'31 180A Last edited by tbirdtbird; 12-23-2014 at 10:02 AM. |
12-23-2014, 09:59 AM | #27 |
I was driving my son to school, engine braking coming down a hill and the cam gear stripped off 3/4 of the teeth. Not just one part but 3/4 of the entire gear. Had her towed home and replaced it with a fiber I had in stock. This was the original gear in my car. So it lasted from 1929 to 2014. Id consider that a good run. It caused no other problems with the car, it just shut itself off.
12-23-2014, 10:47 AM | #28 | |
I have done the same. I drive my coupe a lot on tours. I do not want to be the guy changing a gear on the side of the road. |
12-23-2014, 10:56 AM | #29 |
Fiber gears have always been a problem. The Chev 6 used them also. But not on the trucks they used alum gears on the cam.
Have changed many years a go. Have seen them go at 30,000 miles. That was with a good quality gear made for GM. I see no reason to use fiber. If I was doing a engine for you and you wanted fiber, that would be ok. But if it goes you are on your own. With that said if you are only doing parades and not many miles they would be ok. But why when you can have a gear that will last as long as you. |
12-23-2014, 11:18 AM | #30 | |
12-23-2014, 11:43 AM | #31 |
I've never noticed any noise with aluminum or bronze cam gears, even if I only replaced just the cam gear. The bronze gear is said to be quieter. If you are worried about gear noise just go ahead and use the bronze gear, it costs a little more but not enough more to break the bank .
12-23-2014, 11:55 AM | #32 | |
12-23-2014, 11:58 AM | #33 |
i have a question, what do you guys think of a fiber timing gear?
12-23-2014, 12:11 PM | #34 |
12-23-2014, 12:32 PM | #35 | |
12-23-2014, 12:33 PM | #36 |
12-23-2014, 01:06 PM | #37 |
Because of a few smart a_____, you wonder why some Model A owners don't ask questions. Guys we are all dumb, we are just dumb in different areas. I am glad I gave a few of you something to make you feel superior!
12-23-2014, 01:08 PM | #38 |
Sure you can install the bronze cam gear without installing a new crank gear.If Dan doesn't want to sell just the cam gear, Snyders sells bronze and aluminum cam gears. I have installed just the bronze gear from Snyders without installing a new crank gear.
12-23-2014, 01:21 PM | #39 |
Why die ??????? Its just an old car, its not a Rolls Royce. Even if it made a faint noise, which none of the metal gears have for me, it sure as hell ain't the end of the world. As many have told you several times, the available fiber gears are weaker and mostly don't last very long if the car is driven much..Evidence has been shown here over and over. Its not often that a week goes by that we don't hear of a stripped fiber gear on this forum . If the important thing is that the car will run the rest of your life without stripping another cam gear, install a metal gear, preferably bronze. If you want a fiber gear go right ahead, its your car and like the rest of us you are on your own. What more can anybody say ???????
12-23-2014, 01:29 PM | #40 |
I never had noise with a metal gear, but if I did why should it be different then the rest of the engine. They are not quiets engine ever made.
