Old 04-13-2021, 05:46 PM   #1
russcc
Default Welding early aluminum heads
I friend of mine, an excellent TIG welder, told me than the older cast aluminum can be difficult to weld. Anyone have any experience welding the early heads. The ones I may want to weld are '33, 34, 35 36. They are in excellent condition except for divot here & there. Thank you.
russcc is offline   Reply With Quote
Old 04-13-2021, 05:53 PM   #2
Tim Ayers
Default Re: Welding early aluminum heads
Your friend is correct. Actually, Ford OE heads are of much better quality of any pre-war aftermarket head/intake. If possible, I'd try welding a scrap one first to use as a test before welding the one you want to save.
Some early aftermarket aluminum parts are cast of really poor quality alloy.
Tim Ayers is online now   Reply With Quote
Old 04-13-2021, 09:38 PM   #3
Pete
Pete's Avatar
I have welded a few flathead OEM aluminum heads. Mostly corrosion marks around the water holes. Just like a dentist, you have †o grind out all of the bad before you can put new in. Welding on a junk head will give you practice but the real thing will not always be the same due to inclusions and how much heat the head has had over it's lifetime. I have done it with both TIG and a MIG spool gun.
Both did a good job.
Thread Tools
Display Modes
